*Trim Calculation*
I was asked by a friend what Trim is and how it's calculated and thought this might be useful to someone and might help demystify another aspect of Turbo's that's often considered black art!
The trim calculation is little diameter divided by big diameter squared x 100
(to get Turbine trim reverse)
so for mine it's 61mm/82mm=0.74390243902439024390243902439024
squared= 0.55339083878643664485425342058299
x 100= 55 trim.
It's just a number to express the relationship between the big and little ends of the wheel.
A few makers use trim a few use inducer and a few exducer so it's always good to find out exactly what size the wheel is.
It's one of those NerdyMcNerd things that isn't really of any use in the real world but it's nice to know what they mean when they say "Trim".
Bigger the number the more it will flow.
aye mate
Hiatus over.
Maryland
Little and big diameter of what?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
IJ, my 50-trim? dam at least i thought it was 50.. anyways it is supposed to flow 40% more air that the stock trim... and the stock is 49? did i get ripped off lol
Using my "veggie math" 40% more flow would be 19 units change!
(don't know if there is a direct numerical relationship here)
<edit> It wouldn't be as the flow would increase in a non linear rate.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
i could see that the housing was re-machined out to accept the larger wheel. and it sure made a huge difference in boost? seeing if i can find any paperwork on it now..
edited: :dunno: all i found is the reciept and it says upgrade/rebuild special lol
ill call monday..
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
ya my numbers must be off.. i had to turn to boost down after i installed it so i know it was upgraded..8psi felt like 12psi did before the upgrade...
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
id have to dis assemble the housing for that right/? or you mean try from the accordian inlet side? these 2 measurements?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
ok i pulled the accordian and best guess with a caliper, kinda had to eyeball it due to ps pump. front small diameter is.roughly 2.25 inches.. cant get the bigger dia. without pulling housing.. and stock small dia. is 1.75 inches.. whew... ahhahaha
Joel: I don't think that's a 50 trim ;)!
Sounds MUCH larger!
It might be a 50 trim but with bigger IN and EX sizes which would explain the difference in power you describe! ie: A much Bigger Comp wheel.
