I've posted this before. There seems to be a LOT of gents growling about losing R154's and W58's. As a possible solution, try the Tremec TKO 500 or TKO 600.
This $215 adapter plate from OTT Industries can be used to bolt the GM pattern Tremec's up to a NA 7M W58 bellhousing.
http://www.ottindustries.com/22re-sm.htm
http://www.fortesparts.com/gmtremec.html
Gear Ratio's
TKO 500 - 3.27 1.98 1.34 1.00 0.68 - 500 Ft Lbs
TKO 600 - 2.87 1.89 1.28 1.00 0.64 - 600 Ft Lbs
R154 - 3.25 1.95 1.30 1.00 0.75
Price: $1782
$300 - Shifter
The adapter will also work with a Richmond 6-speed:
Gear Ratio's
3.28 2.14 1.57 1.24 1.00 0.76 4.79 - 450 Ft. Lbs.
Price $2900 with shifter.
Now that IJ is using a Tremec, maybe you gents won't be so nervous about using one too.
Greg
Gear Ratio's
Price: $1782
$300 - Shifter
Gear Ratio's
Greg
