Tremec swap & others....
Greg55_99
55
MA
I've posted this before. There seems to be a LOT of gents growling about losing R154's and W58's. As a possible solution, try the Tremec TKO 500 or TKO 600.
This $215 adapter plate from OTT Industries can be used to bolt the GM pattern Tremec's up to a NA 7M W58 bellhousing.
http://www.ottindustries.com/22re-sm.htm
http://www.fortesparts.com/gmtremec.html
Gear Ratio's
TKO 500 - 3.27 1.98 1.34 1.00 0.68 - 500 Ft Lbs
TKO 600 - 2.87 1.89 1.28 1.00 0.64 - 600 Ft Lbs
R154 - 3.25 1.95 1.30 1.00 0.75
Price: $1782
$300 - Shifter
The adapter will also work with a Richmond 6-speed:
Gear Ratio's
3.28 2.14 1.57 1.24 1.00 0.76 4.79 - 450 Ft. Lbs.
Price $2900 with shifter.
Now that IJ is using a Tremec, maybe you gents won't be so nervous about using one too.
Greg
jbsupra89t
Achieving Balance...
NJ
We can use the T56 Tremec/BW from the LT1/LS1 F-bodies? If so this is VERY interesting... that's a TOUGH transmission...
Greg55_99
55
MA
Nope. Adapter won't work with the T56. It doesn't have the standard GM four bolt pattern.
Greg
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
Excellent info, good to know there is alternative to going auto.
How it fits into the tunnel, any modification required? Do we need custom driveshaft for it?
I can't find how heavy R154 is. Is TK600 (105lb) heavier than R154?
Make it sticky :icon_bigg
Thanks
Vladimir, 89T
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I have absolutely no idea about these transmissions, but could someone tell me if any of them are 6 speed? I always wanted one for the 7m.
eric
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
eric
The Tremec TKO 500 & 600 are 5-speeds. The T-56 is a 6-speed, but will not work with this adapter as previously mentioned.
bkma71
supra coupe
Jun 7, 2005
91
troutdale, Oregon
this is intresting! So if it bolts up to a w58 bellhousing that means using a w58 style clutch and pp correct? If so Im not to into the push style clutch realse but if it will work with r154 style pp and clutch this will be a very nice alternative as Im sick of problems with the r154 (bent clutch forks) and what not but I hate autos even if I do drag my car. And the cost of a full rebuild on the r154 I got priced was well over 2k which just doesnt seem cool to me.
edit- Will this require any other change such as master or slave cylinder?
Greg55_99
55
MA
z1turbo said:
umm, why does the website state that that plate is for a 22re's w56 bellhousing?
The adapter is for the GM SM420 4WD transmission to be bolted up to a W56 bell. It so happens the SM420 has the standard GM four bolt pattern, same as the T5, Muncie, Saginaw and Tremec TKO. Since it bolts to the W56, it also bolts to the W58.
Get in touch with them. You can't use the clutch disk with the kit anyway.
Greg
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
well there was a post not to long ago about the T56 wasnt there? thread was called like "6 speed 7mgte" something or the other...i dunno.
