So I just bought my first supra.::w00t:: Its a red 88 Turbo, with a manual trans, and Targa Top. 94,000m and I was able to get it for cheap.
It has a few small issues that I have been trying to work out though.
First, there are 2 lights on on the dash. The first one is on the left, and the best way I can describe it is it looks like a trash can. It is has done it all; Solid illumination, Flashing, and Turning itself off. Any idea what this light means?
Second, there is a light that has a picture of a car, with lines coming off the back corners of it. I believe it is next to the Door Ajar light.
Now onto the engine issues. The idle is off. It will idle between 1500-2000rpm for a while, and then it will slowly start to basically did, and I have to give it gas to keep it going. I'm thinking the MAF (or is it AFM with Supras) might be dirty/going, but with that basically a wild guess. Any idea what's causing this?
Also I have a very small coolant leak from a coolant hose, and I'm pretty sure it's one near/above the front of the turbo. There is like three hoses there, and Im pretty sure it one of those three. I have no clue what they are called though.
Also, I know its common for speedos to not work, but has anyone heard of a speedo off, like really off. I was driving the Supra home, and the speedo said I was doing 50 (in a 35 :eek3
but the cars behind me were right on my a** like I was going to slow. Maybe it's just the drivers around here, cause they are crazy. But if my speedo is off, how do I fix that? I'll try to confirm with further testing, wheres those electronic speed signs when you need one?
Other than that, I'm having a blast with the car, and its in pretty good condition. And I love looking at it (-the sawblades :barf: hahaha) Thanks in advance for any help, YES, I AM ACTIVELY USING THE SEARCH FUNCTION. :biglaugh:
