Traction control display
May 18, 2007
704
Aarhus
D34DC311 said:
Where does he get his market base to make a living off what he does?
If I sold supras for a living my ass would be working every forum that had something to do with toyota/mark IIIs.
If this guy is what you say he is, the we would welcome his knowledge here, we could definatly use more knowledgable people.
Well, I don't know anything about his economy but I think this is more of a side business for him. He does other things too.
He simply imports Supras and sells parts and running cars. He does not do much for advertising himself.
As an example when I was looking for a Supra I didn't know he existed. And mind you I had gone through every inch of Denmark to look for cars. Only a few months after I bought the car I found out who he was and what he had. I have told him many times to advertise his business a little better.
Kristian_Wraae said:
Since this thread has gone way off course I can just as well ask here:
Does the Race Logic TRC use wheel speed sensors?
I have looked up the AEM and it seems it is not using wheel speed sensors but engine accelation rate.
The MegaSquirt uses the same system.
I want proper TRC.
Which systems use a proper TRC setup with hall sensors on the wheels or alternatively uses the ABS sensors (I don't know if that is possible) ?
RL Does.
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
Wheel sensors for ABS are hall sensors. As long as it is able to calibrate, existing sensors should be adequate.
figgie
Twin Cities, Minnesot-ah
Does use hall sensors that have to be added or use the ABS system?
on a proper TC system yes.
Reason is stock MKIII Supra is Three way ABS. The rear wheel are treated as one which in a TC system can work ok but you want to compare RR and RL with the FR and FL channels. That will give you the most acurate TC system of all.
