jdub;927633 said:Actually Nick, it's the opposite:
Force X Distance = Torque
If you lengthen the handle (say with a metal tube), you'll have to calculate the correct torque value:
C = D(A/A+B)
A = length of torque wrench
B = length of adapter (metal tube)
C = torque wrench setting
D = desired torque at wrench head (socket)
The "twist" using a socket extension is negligible.
jdub;927173 said:(Where do you guys come up with this stuff...MHG thickness, extensions, etc ?!?)
jdub;929219 said:Saying that 400 ft/lbs of torque applied to one end of a 4 ft extension will only amount to 75 lbs on the other end defies Newtonian physics.
jdub;929399 said:75 ft/lbs (w/ moly)...ARP spec for bolts on an aluminum head![]()
Nick M;929688 said:No. You might have misread what I wrote. A longer handle will make more torque, that is what I said. The longer sockets and extenions on the socket will remove torque. The longer the extension, the more it loses.
starscream5000;930973 said:Or, if the bolt doesn't move and the extension continues to twist and finally meets the preset torque, it will still "click", giving an inacurrate reading, an I right in thinking this?
rumptis;925931 said:105 ft/lbs is if you use 30wt oil for lube instead of the ARP Moly or Sealer.
rumptis;931047 said:The only way you are going to loose effectiveness in using extensions is if there is some other side force getting in the way like (Friction). If you twist an 200 foot extension with 500 ft/lbs at one end you will see the same force at the other end as long as there nothing in between causing friction.
Its Newtons 3rd law of motion: "Every action has an equal and opposite reaction"
IwantMKIII;930515 said:You're confusing the concept of torque and energy.
True, it takes work to twist off a bolt and any energy you put into it must go somewhere. In this case, not ALL the energy will be transferred to directly removing the bolt. Some of the energy will be absorbed by the longer extension because it will act similar to a spring. However, in the case of torque, any torque in = torque out on a single shaft regaurdless of shaft length and its angular twist
IwantMKIII;931046 said:input torque will still be transferred to the bolt and have the same output torque.
your are inputing just as much as the bolt is resisting reguardless of twist. The actual drawback and any inaccuracies that would be present actually only involves friction, hence lube can be used and torque can be increased
edit: friction may not even be a factor if the bolt company factored that in within reason, but friction changes from application to application so there will be minor indescrepencies
starscream5000;931108 said:So, theoretically speaking, you aren't loosing any of the torque in the twisting section of the extension, and the torque being applied at the top of the extension makes it all the way down to the bottom, regarless of length, without loosing any torque in the twisted section?
starscream5000;931274 said:Ah, I learn something today.
Of course, if you're twisting an extension by torquing it, it will soon yeild.
Sorry, had a slow moment earlier today.
rumptis;931270 said:Are you talking about swivel?
If so that could cause Friction just like a u-joint would. the more angle on the swivel the more friction there will be and the less torque would make it to the end of whatever it is you are working with.
