torque specs for main caps and rod bolts
19907mgte
25
emporia
As the title says I need the specs for my new main bearings and when im replacing the bearings what all should I replace?
19907mgte
25
emporia
ok i must of missed it thanks im going to be using arp rod bolts and std size king bearings i bought this engine from tigerjapan and i looked at everything before hand and then i put it in and primed it and got it to run let it run for 5 min and it started lightly knocking then it gradually got worse sucks ass... but i appreciate all the help guys
19907mgte
25
emporia
no my crankshaft is fine and i have rods from my old engine i caught it before any damage was done so what bearings should i use then?
Devin LeBlanc
1,830
Las Vegas NV.
If you are using ARP rod bolts you need to have the rods resized no matter what, If it was knocking the rods need to be resized for a undersized bearing along with the crank shaft, You are using a different set of rods and ARP rod bolts is what I think you said, they still need to be resized if they are being used with ARP bolts, wether that set of rods spun a bearing or not.
As far as the crank shaft goes if it was knocking it needs to be resized/ground/polished for an undersized bearing. I guarantee if it was knocking the crankshaft journal clearances are no longer in spec.
Just a heads up, Hope your not planning on just replacing the bearings and hoping its good
zby67
173
Texas
hear is my question what about if your doing a NAT and using eagle H-Beam rods that come with ARP bolts do you still have to get the resized bearings? and im adding ARP bolts to the main caps as well. and thanks for the heads up on the king bearings being a POS. i bought a new crank and it came with them.
You might need to resize the rods for the bearings. Bearing size is all in how big the crank journals are.
zby67
173
Texas
crank is brand new OEM so then STD bearings?
You bought a brand new crank from toyota?
Measure and find out. Most likely yes but i wouldnt guess on something so important and such a pain to change.
TweeT91109
738
Tampa, Florida, United States
Yea I ended up getting ARP rod bolts, then found out they pull differently then the stock studs, so I had to get them line honed to make them true again. Lol, that was a bummer cause I didn't find that out till I assembled the bottom end a 2nd time. Thanks a lot Iboughtasupra. lol jk man.
suprarich
Guest
Nov 9, 2005
2,187
ohio
STD toyota and std aftermarket bearings are two different things. You need to measure everything, and adjust your new crank as needed with aftermarket bearings for proper oil clearance, or order the correct select size bearings from toyota to set the proper oil clearance.
IBoughtASupra
4,455
Queens, NY
No problem man.
zby67
173
Texas
kinda had to the key ways on the original crank were fucked. ok so ill hold off on buying bearings. have the machine shop tell me what size bearings i need and ill bring in the eagle rods and crank when i go and get the block taken care of. thank you for the heads up or my project would of hit rock bottom fast!
