Justin727;1525313 said:I can do ya 1 better moy! I got 3 coils NEW for free! Inventory Scrap HA HA
IBoughtASupra;1528778 said:Ok, so this is what is needed,
-Coil Packs From 2001 IS300 With A VVTi Engine
-7M Coil Pack Harness
Any special spark plugs to use to get the plugs to fit? Could Aaron make a new coil pack harness if I called and asked him to since I have bought everything for all the Supra's we have built from there....a little over eight grand.
Took, would you be able to make a coil pack cover like that for me? How much would you want, PM ME.
Seems i changed the order of the coils, i put them in this order:RazoE;1538713 said:Sounds like your wires are loose, make sure the spring is touching the sparkplug, and make sure the wires coming off the coilpacks are on nice and tight. Remember, only the boots coming off the wires plug in nice and tightly, the coilpacks are actually loose, and should be held down, BUT for just testing and idling, only the spring needs contact. If you're missing the spring on 1, then you found your problem..
EDIT: on second thought do you have them in the right order? You may have 1 swapped, as in where there should be a coilpack, you have a spark plug wire. The coil packs should be in cylinders 2, 3, and 5, wires should be going to 1, 4 and 6...
Oh and incase no one has mentioned this, you need to remove the spark plug gallery to install them
IBoughtASupra;1559694 said:Have your local part store order them or get them online from RockAuto.com
RazoE;1559685 said:maybe your cold start injector is acting up, and running too rich at start up, or something...
