Titan Harness Bar Install, difficulty mounting.
improved
Running!
Apr 4, 2005
195
California
Hello forum,
I'm installing my Titan Harness Bar with a small hang-up. The main bar fits tightly between the stock mounting points. So tightly, that proper installation would require me to trim interior pieces for the correct installation.
I''m I right to assume that triming is necessary for correct installation?
Matt-
Dec 3, 2003
6,653
Canada
improved;1036348 said:
Hello forum,
Matt-
ZERO trimming for this part. I JUST installed one in my brothers Supra last Sunday. It is a very tight fit but it does work. ;) I bolted the bar to the one side then put a jack under bar (wood on top of jack so bar wouldn't get scratched) to bring it up for the hole to line up. You can place the jack on a tire or something since it would obviously not reach otherwise.
HTH
Again, do not trim anything.
Duane
improved
Running!
Apr 4, 2005
195
California
HTH
Duane
Thank you Duane, that bar sure is tight. I'll try the floorjack tomorrow. I'll post the results.
They sure did Chris. Thank you for your help.
Thank you again,
Matt-
shaeff
Kurt is FTMFW x2!!!!
11
Around
Excellent, glad to help! :) Did you ever get the harness bar in?
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
The one I have, not installed yet, but was in Sean's car(2JZMK3) seemed a bit tight, even with the panels having holes drilled in them and the bar going thru them.
I would PM Sean(2JZMK3), his looked really clean with it hiding behind the panels.
Denny
improved
Running!
Apr 4, 2005
195
California
Hello Forum,
I test fitted the bar and used Duane's method. It worked like a charm. No cutting or trimming necessary.
Now I need to buy some lock washers and thread sealer, so the bar is totally secure.
I have one question though. I am not using my car for competition, only for fun on the weekends. I want my Supra to be safe, so I'm considering using Cage padding on the Titan Harness bar.
Does this seem unnecessary?
Matt-
Dec 3, 2003
6,653
Canada
improved;1046101 said:
Hello Forum,
Matt-
The padding is not needed IMO. I am glad my suggestion worked out for you. :)
Duane
