WeDgE said:13.8 @ 105.7mph, T78, 13psi, bald drag radials-P), 3280ft.
Need more boost to get this turbo into its efficiency range!
WeDgE said:Did some talking with a friend of mine and a change back to the Turbo differential could help immensely. I won't be shifting into 4th right before the end and I'll be putting more load on the turbo, building boost faster/generating more power(I hope!).
my 3rd goes to almost 120! loldrjonez said:ummmmmmmmm, you will be shifting to 4th no matter what.....3rd tops out around 85ish....
tissimo said:my 3rd goes to almost 120! lol
Heckler said:Everything I have read points to using a lower-geared ratio like the 4.30 as opposed to the 3.73 I have at the moment. I am redlining 3rd at the end of the track at ~100mph, and I wish I could get some use out of fourth gear!
drjonez said:The idea is to gear the car such that you perform the lowest number of shifts possible. if you're near or @ redline @ the end of the 1/4, you've done well.
no, a r154.... just reving to 7600 w/ a 3.73.. lol..drjonez said:curse you auto trans!
the idea is to gear the car such that you perform the lowest number of shifts possible. if you're near or @ redline @ the end of the 1/4, you've done well.
Heckler said:If I took that literally, I may just try starting off in third! :icon_bigg
I think there are a number of things going on here. We want to maximize the power under the curve, while at the same time minimizing the amount of time between shifts (and the number of shifts), where there is no power to the wheels. But those two goals conflict with a conventional setup.
From what I understand, the reason that auto trannies do so well is that they can minimize the amount of time between shifts, while keeping the car in the right gear. For a manual, shifting time is much slower (including loss of boost, etc) so we lose out. But we still have to keep the motor reasonably within it's power band.
Damien, what is your rpm in fourth gear at the end of the strip? I'd like to do some number crunching and see if I can get an estimate of how close (if at all) I'd be to redline in 4th with the 4.3 diff. Sorry, this weekend is out due to family stuff.
Jim
