Timeslips, post em up!
toyman1987
62
Omaha
this is last year, there WILL be a 10sec posted this year:naughty:
BTZ
Burnaby
60' 2.373
330 6.146
1/8 8.942
mph 88.41
1000 11.274
1/4 13.227
mph 113.99
57 trim ct-26 @ 15psi on a wet track with a slipping clutch, lol. spinning all the way down the track.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
No scanner here either!... 13.3 @ 107, 60'=1.94...That is with Duane Stephens @ the wheel!:aigo: :icon_razz .57 Trim w/Lex+ stock inj. AeroVfpr BIC DDP w/Blitz Nur Spec Stage II clutch (which is probably toast now!):cry: slipping bad after a 20psi boot, and my fucked up "dry" burnout:aigo: aluminum driveshaft, couple of other thingys here and there, nothing special. Car definately has 12's in it with the right clutch!:icon_bigg...oh yeah, I forgot to say, "POS" manual boost controller, that spiked up to almost 20psi, hence the demise of the SPEC clutch!
Dec 3, 2003
6,653
Canada
Hey Tom.. The car with only 15 PSI was capable of 13.3 and if the clutch held the 20 PSI, it would have been a 12 with ease. :naughty: Actually with a better 60 ft, it would have been a 12 on 15 psi ;)
Duane
Thanks for letting me drive the Supra as I had a blast! :biglaugh:
BTZ
Burnaby
tires? did you notice any more power when u swapped to the 5 spd? I have a similar set up with s-afcII, 4.30's, 550's, minus afpr and mine was 3450 at the track with me in it. 13.22@113.99mph at 15psi 2.373 60'. was that at mission? I will be back once the track is dry and my new clutch is in. the disk arrived the other day! I think you should be able to get a lot more power out of the 57trim with a better tune.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Oh yeah! Lots more power with the 5-speed! I also have a SupraSport aluminum ds. The runs were at Pacific Raceway in Kent, WA.
BTZ
Burnaby
I think he installed the driveshaft the same time as the 5 spd. but i was thinking 20% loss of say 300 compared to 15%, it must be 15-20 hp at the wheels he gained from the swap not including the driveshaft.
Dec 3, 2003
6,653
Canada
Nope, when I did the swap for him he had an OEM drive shaft.
Duane
kikdurazz
what's the birdcage for?
winnipeg
Well Just got back from the strip today.
don't have a scanner but here's the slip
1.0650 ---reaction (sleepy)
1.9981 ---60ft
5.6980 ---330ft
8.1200---et at 594ft
8.6410---1/8 ET
86.37 ---1/8mph
11.1400---1000' ET
13.2329---1/4 ET
111.65----1/4 MPH
Boosting at 18psi.
Fairly happy. Need to get the 60 down and and shift faster. Was hoping for a high 12 today.
Mods: 60-1 CT-26, Spearco intercooler, hardpipes, 3in mandrel exhaust, 550 inj, Lexus AFM, SAFC, aluminum DS, Spec stage 3 clutch.
GTsupra
20
perth australia
hey guys,
12.720 sec
115.23 mph 185.44 kph
60' 2.209 sec
330' 5.633
660' 8.404
1000' 10.754
tyres: 255/50r16 m/t street et
t70 turbo,fmic,fpr,p&p head,michrotec ltx12 ecu,3mm hks h/gasket,running 20psi. stock bottom end.
that dam 60' foot time.. can't get any better than a 2.18 (thats on m/t semi slick)
