Well, I did call someone at Sound Performance on this matter and they suggested doing the HG job however, they did suggest that if I've never done this before to at least replace the stock bolts with the Arps studs without removing the head. I'm going to at least do that if not the whole HG job.DeMoN2318;2044677 said:I would... just retorque the bolts (one at a time, crack loose, then torque)
Pulling the head just opens doors for more issues to arise...what if you pull the head and the block is pitted? You gonna pull the block and have it surfaced? Or just gonna roll with it?
You gonna do cam seals while you have the head off? Water pump? Timing belt? Gonna do adjustable cam gears?
It will spiral out of control...hoses, lines, little misc stuff...it'll turn into a big expensive job.
I also hear its tough to get the head back on the block with ARP studs and the block installed in the car.
Why not just run it till it blows? Then fix it? As long as you pay attention to temp and birdcage, occasionally check fluid to make sure it didn't drop...you should notice the bhg when it happens, and before it causes more damage
Thats the route I'm going
Sigh....all I know is, if I don't do the full HG job (new stock HG and Arp studs), I'm not going to feel comfortable putting my foot/gas pedal to the floor w/ this 57trim and lex550s setup. I'm going to feel like I'm about to blow the f**k up which will cause me to drive very conservatively (not fun). Lol ...not saying I wanna drive hard either way, just saying, I need a "peace of mind" when I go pedal-to-the-metal.
As for the cam seals, they were leaking oil when I got my Supra back in 2013 Oct.; took me forever to build confidence to get the job done but I replaced them in June 2014. As for the water pump, I purchased it in July 2014 and....confidence gained thus, I did it in Oct 2014 after blowing the second coolant hose. I will be doing the timing belt regardless of a full HG replacement or Arps studs only or retorque. And vacuum hoses will also get replaced as I go along this process.
It is what it is....its just that before owning this Supra (my first ever) I've been reading up on these forums (mainly Supraforums daily since 2008) about BHG issues/nightmares with 7M engines....and simply put, it scares me....I don't need that life; increase boost or and detonation, BHG, contaminants in bottom end, spin rods - rebuild....I don't need that life. Maybe, I've been on Supraforums (daily far too long) and thats why I'm paranoid about this BHG issues on 7Ms. Ptsss, I can't remember the last time I took my 7M to redline....had to be back in the summer on the 1/8mile pass I did...
I don't mean to be annoying but I'm trying to save my 7M from savagery.
