I need to add my 2cents.
First of all, blow-thru "technology" (if you want to call it that) has come quite a ways, there are TONS of properly tuned turbo-carb'd vehicles out there nowadays. That being said, theyre mostly v8s which is nicer for the less precise atomization of a carb. Second, those split-domitators you posted are not set up for boost, and even if they were, it would make for a strange "hat" on top of it, plus the fact that 3 of them woudl be too big. Now for the guy that suggested a 1050cfm dominator, please do some research. Carbs act MUCH bigger than they actually are under boost. There are many v8s making over 1000whp on a 650cfm blow-thru.
That being said, i will be doing a blow-thru on my chevelle whenever i get around to it, and this forum...
http://www.theturboforums.com/smf/index.php?PHPSESSID=2ab7fa38872d72779b487b65b66cc5c0&board=13.0 is a valuable resource for blow thru. If i were to do this on a supra (and dont think it hasnt crossed my mind) i would make the intake mani so that it goes from 6 adjacent runners..
0 0 0 0 0 0
..sweeps up 90* towards the hood, and ends up in 2 rows of 3 to help get them tighter together for the relatively small carb flange, like this...
0 0 0
0 0 0
Now also keep in mind, that as IJ said, a proper programmable ignition control (such as the MSD digital 7programmable) is about $800, plus about $1000 for the carb, plus mani fabrication, plus welding up the injector bungs in the head, plus a crank trigger, plust the carb hat, plus jets, plus powervalves....blah blah blah.
It would be super interesting, and i would appreciate the standing-out-from-the-crowd aspect, but at the same time, you gotta think when it might be just too much...
(god i should take my own advice.....)
