I gots the vsv Kyle. Sorry forgot to call you. Was too excited looking at my pretty 3.0 liter hehe.
Anytime after 2:30 pm , you can swing by my place. Bring IJ as well.
If the Amp is blown you won't get hot air full stop amen
You can wire the Heater Valve open or remove it totally and there will still be no hot air nada zip zero zilch not a skerrick nyt nothing sans heat cold even.
Ok what happens if you pull the Vacc line on the actuator and plug it?
(just went back through the entire thread sorry I thought you had the more common no heat bug)
Next thing to check is run the motor put your finger on the end of the vacc hose and have someone switch the heater on and off you should feel it suck/not suck.
The check valve coming from the diaphragm which controls the HCV, I'm pretty sure that's backwards.... it only works when facing the right direction and the way that it's on there no vacuum would ever hit the diaphragm.... unless the check valve is shot.
The little black and white thingy in the middle of the vacuum tubing.
