The people's car - SupraMania.com 7m build
jsnowman76
In need of another supra
Oct 17, 2006
289
Elk grove, CA
^agreed a poll would be a great idea.
its too bad you live so far away because even though I can't supply you with parts, I would love to get some wrenches and some elbow grease put into it.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
I think you should tub it too ;)
Should paint if forest green, and call it "Project: JZ killa" or "Project: Underrated" :icon_razz
ps....ygpm
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Supramania red! With a black center and white lettering on a raised cowl hood! :naughty:
Hey Rich if someone is willing to pay for shipping (or we can tag team deliver it) I'll find a core and build a hood for it. If you would rather go CF or FG I understand, but I would be happy to lend what I can in labor at least.
I actually also have a pull off water pump. Worked fine with no issues, just wanted to replace it in my build to be safe. if ya still need one I'll donate.
suprarich
Guest
Nov 9, 2005
2,187
ohio
why sleeve the block? The 7m should be stout enough as is.
This is something I would do in the end, with a greater than 1000 hp block. The reason I want to do that is because sleeving allows you to use the same block over and over. By the time you spend the the money preping and filling a block, it is nice to be able to press new liners in and out to rebuild as many times as you want.
IJ- I understand the restrictions on our block, but this is why i wouild use a NEW 1993 or 1992 block. I don't think I need to explain the reason on the late model block, and filling the block will hold the thin walls in place with a sleeve. It has been done before. We would machine the block from the inside, upside down.
BTW powerglide over th if its going to be track only.
Here is the thing about that, and I will look for some answers on this. I can build the tranny myself, but only want to do it once. The pg needs an aftermarket case when you near 8-900 ft lbs. The th400 does not, but no one makes one anyway. The PG needs a 390 to 430 ratio diff to work well, and for the car to be really light. The th400, when using the taller gear we have in th late model diff, will give a bigger mph, and the extra low 1st gear will help with the weight of the car. The pg will work well with the high rpm our motor will make. The th400 will need a special pump in it that can handle rpm's above 7000. Cost will be middle upper 2000's for each for 800 ft lbs. Above that, the pg will cost more because of the case.
Slow - I was going to stick to the IRS untill it no longer will hold anything. We need someone who can airbrush to put a pic of the turbo sucking up a 1jz!!
Weezl - if you want to do a hood, it would remain your property and I would make sure your name was all over it. We can get it to the car somehow. The 1000hp mtor I will use a belt drive wp. the next motor will be electric. I have a good waterpump off another motor already.
Maybe someone can photoshop an idea for the supramania.com decal over the side of a supra???
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Well looks like Im moving again, but once I sort that out I'll see about making a hood. Any particular ideas on that? 2" cowl? turbo vent?
suprarich
Guest
Nov 9, 2005
2,187
ohio
Rich: If you're hard filling the block that's another story!
This IRS will hold just about anything you can chuck at it!
Of course the second motor will be filled!!:biglaugh:
what the hell is that diff out of, an H1?
suprarich
Guest
Nov 9, 2005
2,187
ohio
Turbo vent would be cool! we could do the airbrush of a 1jz being sucked up right there!
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
catback said:
if someone like jeff lange or IJ or dr jonez or and so on and so on, came up with something like this it would have more credit.
Rich has credit in my book...
I just cleaned this up a bit, lets try to keep this civil... If you dont want to support Rich, then dont... If you want to help, donate, encourage, whatever: then please do... Try to keep the posts on topic, I really dont want this thread inundated with post whores rattling off 3 syllable remarks and smiley faces... ;)
suprarich
Guest
Nov 9, 2005
2,187
ohio
Crap, I was going to take the block over to my machine shop to be tanked and fluxed, but it snowed last night and the roads are full of salt. Lets call the car "Underdawg" I will get a little pic of that flying dog cartoon character to put on the car.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
hehe
suprarich
Guest
Nov 9, 2005
2,187
ohio
A supra used to be called a dawg. That is why I thought of that.
Jake - That pic made me lol! That could be the one.
