UPDATE: Current pic and stats
Chassis: MA70, 1987 Toyota Supra w/ Sport-package. 29,907 produced
Engine: 7MGE, DOHC 24V FI Inline-6.
* Displacement: 2954 cc (180.2 cu in)
* Bore: 83.00 mm (3.27 in)
* Stroke: 91.00 mm (3.58 in)
* Piston speed. 64.6 FPS @ 6500 rpm fuel-cut
* Compression Ratio: 9.1:1
* Weight: 119.5 kg (440 lb)
* Power: Rated for 200 hp@ 6000 rpm and 196 ft·lbf @ 4800 rpm. <Haven't Dyno'd yet
* Cranking Compression: 150psi (Toyota FSM rates good between 146-156)
* Oil: Currently running Lucas 20/50 Racing Oil, plan on swapping to AMSOIL full synthetic w/ dual remote-filters and adding an oil cooler.
* Coolant: Currently running Xerex G05, plan on swapping to Evans.
* As part of the Supra's technological arsenal the 7MGE features Toyota ACIS (Acoustic Controlled Induction System), a method of controlling air compression pulses inside the intake manifold to increase power. <Shit works, kicks in @3500RPM feels like VTEC lol.
Suspension: Double-wishbones on all corners. NEED to replace tired old springs and shocks.
* TEMS (Toyota Electronically Modulated Suspension) gives the shocks 2 settings which affected the damper rates; a third is automatically activated at WOT, hard braking, and high speed maneuvering. <Shit works.
Brakes Stock 4 wheel disc. No ABS.
* Brake Fluid: ATE Super Blue Racing.
* Pads: Stock, plan to upgrade to EBC, HAWK or Porterfield.
Powertrain Stock W58 5-speed transmission. Stock Clutch, Stock Flywheel. Stock clutch-type LSD. Plan to upgrade to SPEC Stage II clutch and Flywheel and KAZZ Torsion-type LSD.
Transmission Gear Ratios:
* First Gear: 3.285:1
* Second Gear: 1.894:1
* Third Gear: 1.275:1
* Fourth Gear: 1.00:1
* Fifth Gear: 0.783:1
Final Drive Ratio: 4.1
Exhaust Stock Manifold, Stock Catalyst, crushed muffler. <Loud
Wheels/Tires 16x7" ARE one-piece split-5-spoke cast-alloys, 225/50r16Goodyear Eagle RS-A's
Interior Victor F1 Concept D-wheel. Blue Anodized Ricer pedals. Cut shifter. Custom Stereo.
Exterior Custom Ricer 2-tone spray-paint. Z32 Headlights.
So this is my first Supra. I picked this up behind a barn for free. It's an 87 non-turbo, lots of miles on the chassis but the motor has a rebuilt head.
Here's the first issue I noticed on the car. Cut springs
A little about myself... my nickname is Nar. (short for Narayan, pro-nounced nuh-ryan) I'm no stranger to modifying cars... I've had an RX3, a few RX7's, and a Z. I work at a speed shop. Driving is my favorite hobby. Most of my skills I learned on the touge but I'm also a high-performance driving instructor at my local track.
I just recently got the car running again and there's a huge list of problems I want to fix. The big issues at the moment are it wont idle (you can't even start it unless you floor it) and it stutters at WOT if your driving it. The check engine light is on and I got the following codes: TPS sensor, O2 sensor, Knock Sensor. Next I plan on checking the EGR valve, ignition timing and wether or not the exhaust is clogged. Any other ideas?
Thanks
Thanks
