PS- you said that the head was rebuilt- Are you sure that the cam timing is correct? A couple of teeth off, and the car won't hardly run.
supraguy@aol;1162261 said:PS- you said that the head was rebuilt- Are you sure that the cam timing is correct? A couple of teeth off, and the car won't hardly run.
NARSupra;1162551 said:Update... I figured out the intake manifold is leaking where it bolts to the block at the manifold. So whomever put it on in the first place couldn't even do that right.
IJ.;1162581 said:Funny place to bolt the intake mine is on the head![]()
Rennat;1167797 said:whats that big round thing bolted below the VSV and to the right of the knock sensor?
and there were only 2 actual studs on my intake manifold... and then the two for the EGR.
NARSupra;1167821 said:Well I'm just gonna go with all studs I think... and at the moment I'm at my night job and I don't have time to figure out what the big round thing is... this is the best I could find on short notice...
http://i3.photobucket.com/albums/y81/dirgle/7mgevhremove1.jpg
NARSupra;1173543 said:So after staying after hours all week here at the speed shop I've finished resealing the intake manifold, installing the rebuilt fuel injectors... and various other chores. However, after all this the car is surging. I checked the TPS its in spec, I played with adjusting the TPS and the idle speed screw to no avail.
Here's the troubleshooting list here from the factory manual online... but its for an 89...
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=16
Here's a vid...
http://www.youtube.com/watch?v=cc9ccHdk_Q8
