The NARSupra
NARSupra
45
Chico, CA
UPDATE: Current pic and stats
Chassis: MA70, 1987 Toyota Supra w/ Sport-package. 29,907 produced
Engine: 7MGE, DOHC 24V FI Inline-6.
* Displacement: 2954 cc (180.2 cu in)
* Bore: 83.00 mm (3.27 in)
* Stroke: 91.00 mm (3.58 in)
* Piston speed. 64.6 FPS @ 6500 rpm fuel-cut
* Compression Ratio: 9.1:1
* Weight: 119.5 kg (440 lb)
* Power: Rated for 200 hp@ 6000 rpm and 196 ft&#183;lbf @ 4800 rpm. <Haven't Dyno'd yet
* Cranking Compression: 150psi (Toyota FSM rates good between 146-156)
* Oil: Currently running Lucas 20/50 Racing Oil, plan on swapping to AMSOIL full synthetic w/ dual remote-filters and adding an oil cooler.
* Coolant: Currently running Xerex G05, plan on swapping to Evans.
* As part of the Supra's technological arsenal the 7MGE features Toyota ACIS (Acoustic Controlled Induction System), a method of controlling air compression pulses inside the intake manifold to increase power. <Shit works, kicks in @3500RPM feels like VTEC lol.
Suspension: Double-wishbones on all corners. NEED to replace tired old springs and shocks.
* TEMS (Toyota Electronically Modulated Suspension) gives the shocks 2 settings which affected the damper rates; a third is automatically activated at WOT, hard braking, and high speed maneuvering. <Shit works.
Brakes Stock 4 wheel disc. No ABS.
* Brake Fluid: ATE Super Blue Racing.
* Pads: Stock, plan to upgrade to EBC, HAWK or Porterfield.
Powertrain Stock W58 5-speed transmission. Stock Clutch, Stock Flywheel. Stock clutch-type LSD. Plan to upgrade to SPEC Stage II clutch and Flywheel and KAZZ Torsion-type LSD.
Transmission Gear Ratios:
* First Gear: 3.285:1
* Second Gear: 1.894:1
* Third Gear: 1.275:1
* Fourth Gear: 1.00:1
* Fifth Gear: 0.783:1
Final Drive Ratio: 4.1
Exhaust Stock Manifold, Stock Catalyst, crushed muffler. <Loud
Wheels/Tires 16x7" ARE one-piece split-5-spoke cast-alloys, 225/50r16Goodyear Eagle RS-A's
Interior Victor F1 Concept D-wheel. Blue Anodized Ricer pedals. Cut shifter. Custom Stereo.
Exterior Custom Ricer 2-tone spray-paint. Z32 Headlights.
So this is my first Supra. I picked this up behind a barn for free. It's an 87 non-turbo, lots of miles on the chassis but the motor has a rebuilt head.
Here's the first issue I noticed on the car. Cut springs :rolleyes:
A little about myself... my nickname is Nar. (short for Narayan, pro-nounced nuh-ryan) I'm no stranger to modifying cars... I've had an RX3, a few RX7's, and a Z. I work at a speed shop. Driving is my favorite hobby. Most of my skills I learned on the touge but I'm also a high-performance driving instructor at my local track.
I just recently got the car running again and there's a huge list of problems I want to fix. The big issues at the moment are it wont idle (you can't even start it unless you floor it) and it stutters at WOT if your driving it. The check engine light is on and I got the following codes: TPS sensor, O2 sensor, Knock Sensor. Next I plan on checking the EGR valve, ignition timing and wether or not the exhaust is clogged. Any other ideas?
Thanks
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
TPS - just need to adjust per the TSRM.
found here.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
clean the o2 sensor and then see if its really bad... that will obvisouly give you too much fuel which wont make the car too happy.
if your getting a code for the knock sensor you either have bad wiring to them, or there bad... but that will effect your driveability a lot.
obvisouly you need to check timing, and make sure the vacuum lines and intake lines are all hooked up right.
just go read through the TSRM in the areas that you have problems, and most issues can be solved rather easily.
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
Welcome:icon_bigg
Where is Chico, Ca.?
I would clean the throttle body and check for vacume leaks, a good once over will do miracles
NARSupra
45
Chico, CA
found here.
http://www.cygnusx1.net/Supra/Librar...3/default.aspx
I really wish I had a TSRM. I haven't been able to find one used anywhere so I'll guess I'll have to buy one. I've found that one online before but I can already tell from comparing my car to an 89 that there are significant differences. For instance I tried swapping the EGR off an 89 unto my 87 and they are obviously different. The later years seem to have less vacuum control solenoids as well.
I didn't think the oxygen sensor or the knock sensor would prevent the car from starting? It literally will not get going unless your foot is nearly floored when you turn the key. Otherwise it just stutters a a bit and dies again.
simpsons7s said:
Welcome
Chico is about 2 hours north of Sacramento. I replaced all the vacuum lines already and I cleaned the TB and the motor thoroughly with AMSOIL powerfoam. I've moved so much that its no joke I've seen more of this state then most will in their lifetimes. I spent plenty of time in Socal.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
your starting issue is most likely due the TPS not being adjusted right. its probably on backwards, thus why you need to FLOOR it to start. because starting is suppose to be 0&#37;... not 100%. haha
that TSRM is for a 90... so yeah, but a haynes manual has most of the same pictures, and same info. the basic info, like the TPS, codes, how to adjust things are the same, but yes things like the EGR, and other small things may be different.
but the biggest difference you'll find with things is if their turbo or not...
you have an 87, its the most common supra known to man, so you should have no problem finding ANYTHING you need on this site, if you need another throttle body, or a TPS, i have 2 or 3 i could ship for $5.... I use to have an 86.5 n/a so i have a shit ton of left over parts, so yeah...
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
its always nice to have the manual in front of your face, especially when doing TPS adjustments, and other small things where you dont wanna run back upstiars to see what the voltages are suppose to be.
NARSupra
45
Chico, CA
Nice I may have to take you up on some parts Rennat and yes I agree an actual service manual is gold. I've been relying mostly on Alldata... or as I like to call it somedata lol.
Is there a trick connecting the TPS? What you said makes a lot of sense.. I looked more closely at it and the spring mechanism inside looks like it wouldn't work properly if the plastic tabs didn't snap over the metal fins on the throttle body exactly.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
The Cygnus site that the link took you to, is the complete Factory service manual for the car. I find it to be invaluable!
Welcome to the site ZAR! You will find most people here will encourage a turbo swap. You will also find more knowledge than Toyota around here.
NARSupra
45
Chico, CA
I've never owned a turbocharged car before, just never seems to happen. I'm sure it would be nice, but the type of driving I do favors NA's anyway so I'm not worried about having the fastest car around. I just want my car to help me be a faster driver.
NARSupra
45
Chico, CA
I have made progress but it isn't helping... I noticed that the Idle speed Controller connector had some broken wires so I fixed that, replaced the O2 sensor and knock sensor and adjusted the TPS some more and it seems now when I start the car the check engine light doesn't stay on anymore... instead it flashes with the battery light?
When I get it to start by flooring it, I can get it to rev again once but then it dies again no matter what?
NARSupra
45
Chico, CA
DETONATION666;1161347 said:
Is that an RX3 in your SIG???? what did you do to it!!
Heh, that was my SCCA Pro-Rally RX3. I had my fun with it rally racing,
and I was planning on modifying it for track use as well. I was in the middle of the planning stages for that and I drove the car to Thunderhill to help out with a drifting competition. But the reason I needed to modify that RX3 for track use was because it had lots of ground clearance and really soft suspension.
The event organizer is a good friend of mine and he talked me into drifting the RX3 because I had plenty of practice drifting my RX7's previously. I ended up rolling it and sliding it on its roof a hundred feet or so.
NARSupra
45
Chico, CA
Update... replaced alternator and put a brand new TPS on. The new TPS helps, I can drive the car around but it'll still die if I let the rev's drop below 1100 or so and it still won't start unless its floored.
But clearly what I've been doing helps cause there is no longer any check engine light.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
all this work on the TPS... but did you ever set it to the TSRM specs and prodecures?
sounds like you have a lot of stuff wrong though... car have good spark plugs, wires, and the timing is right?
and does the car idle at all? or does it have to be kept at 1100 with the gas a little down?
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
NARSupra;1158119 said:
Any other ideas?
Thanks
Toss it and start over with another supra maybe. :biglaugh:
You got a lot of bugs to work out. How's the condition of your engine harness? 935motorsports rebuilds engine harnesses if yours is f-ed up.
You can get stock springs on here for near nothing. People will just give them away.
Doing a turbo swap on supras is very easy. I did one ealier this year. Toyota was very kind with the chasis. Turbos and NA's have the exact same chasis so the bolt holes are already there for everything and it's pretty much plug and play.
Good luck! Oh and pack your bags with lots of patience. You will need it. These can be very frustrating cars.
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Bethpage, New York, United States
Rally kicks ass. I thought I was the only one in the USA that really loves it but there are a few people around that get into it. "Not the BS at the Xgames" Group B Bitches!!
Ive wanted an RX3 for a crazy long time!!! you better fix it
