The Build of p5150 - 2JZGE-T, GT4294, Paint, and more stuff
p5150
ASE and FAA A&P Certified
Central Idaho
** NEW PICS ON PAGE 11*** Well, after waiting awhile I decided to post up what is going on with the build. I decided to ditch the 7M because it is no longer cost effective.
Most of the stuff has been acquired but some is still left to purchase. Going in my 88 MKIII is:
Engine
Stock shortblock 2JZGE-T measured/miked out
Mild port on head with deshrouded valves
Cometic 8.6:1 c/r (0.76") headgasket
Schneider 260 regrinds
Turbo and Intake
T\GT4294 w/thermal-coated 1.01 4" vband discharge
Ching chang chow braced SS exhaust manifold (thermal coated)
50 mm ching chang chow wastegate
3" intercooler piping
4" full exhaust
12x24x3" intercooler
q45 throttle body
custom front facing intake
Fuel/Ignition
2jzgte AEM EMS
re-pinned 2jzge wiring harness
1000cc precision injectors
dual pumps
dual-feed stock fuel rail
AEM CDI
2jz GTE Coil Packs
7m CPS
Trans/Clutch
1jz bell housing on R154
ATS Carbon triple-plate clutch
Chrome Ruff Racing 280 Series wheels
18x8.5 35mm 245/40
18x9.5 45mm 275/40
Since this is just a build thread, I dont want to argue the whole point of 2j vs 7m and why I went 2j but if you want to talk about it check out one of these threads:
http://www.supramania.com/forums/showthread.php?t=33721
http://www.supramania.com/forums/showthread.php?t=36088
http://www.supramania.com/forums/showthread.php?t=34043
p5150
Central Idaho
I will upload more pics later when I get microsoft office re-installed.
p5150
Central Idaho
supra90turbo said:
Looking good man!
What've you got all over everything though? Sheetrock dust?
Dust from block sanding the body. I havent painted outside the engine bay yet.
p5150
Central Idaho
Yeah the rest of the car will be the same color. Its a BMW green but I forgot the name of it.....
Im probably going to go with these wheels:
Gilsdorf
Street Dragon
Jun 18, 2005
244
Reno, NV
Nice build! Good luck with everything, it will be a killer ride once it's finished. Love the color choice.
Matt
p5150
Central Idaho
boostadikt said:
wow.... check out the lip on that sucker, what is the offset for front and rear?
35mm up front (18x8.5) and 45 mm in the back (18x9.5)
AAHHHHHHHHH my eyes.......I'm blind!!!!!!! Those are some shiny wheels my friend. I love them and with your green car it is going to be sexinesss personified for sure...........:love:
What type of hp numbers are you shooting for? I can't wait to see this thing come together and get dyno'd. Definately subscribing to this thread. Good luck
p5150
Central Idaho
I should have it running in a month or two. i still have to drop 2300 on the clutch and finish building the manifold, IC pipes and exhaust.
Finish the wiring....
After that I have to spray the paint....
p5150
Central Idaho
With the GT4294 I should be able to put down a healthy 700 hp. Possibly more. We will see how she acts when I turn up the boost....
Damn there must be a rule or something in Washington, that if you own a supra, it has to put down more than 650 rwhp.................:biglaugh:
I know of two supras now that meet that law.
p5150
Central Idaho
I got my turbo in the mail today. I think I strained my back bending over the fender to test fit it. Its fucking huge. It looks like I will have to put a spacer in to lift the turbo enough for the compressor housing outlet to move to the 6 o'clock position. About 2 inches should do it but more test fitting will tell for sure.
Notice the size of the cam gear vs inlet?
The intake manifold is coming along pretty well. I was surprised how easy it was to weld aluminum with a wire-feed MIG from harbor freight. It took awhile to grind down though.... Pretty much all I have left with the FFI is to position the q45 flange and weld on the caps. Some grinding on the exterior to clean up the beads too.....
p5150
Central Idaho
Well I have a few different options to make this thing fit. Basically, it fits but the the compressor cover is pretty close to the strut tower and the compressor outlet goes directly into the frame.
Im deciding between:
Mounting this turbo on a 3" spacer - this will require a modified hood.
Modifying the compressor outlet to include a 90 degree bend in the end of it.
:dunno:
