MKonmac;1438850 said:
			I understand that the 7m sender has no clearnece for screwing in but does it have the correct threads to screw into the block?
meaning that i can take the sender to the local parts store and just get a braided line using the sender as the piece to test the treads?
Thanks
Yes its the same thread as the switch in 1jz the hose is just an extension.
You can also buy the union bolt from toyota for about ~20 and replace the one in the oil cooler and screw it into the top of the union bolt in the oil cooler directly!
The union bolt is off a 2JZ-GE there is two of the one with the 10 mm hole one without.
You might have to trim just a verry little bit off the oil cooler with a grinder so it will screw into the union bolt really good.
				MKonmac;1438853 said:
			No when i hook up the wire for the temp the temp gauge just keeps going up and up and up. someone mentioned that it could be a ground.
What wire do i ground. (brown) but where do i find this wire?
Thanks
The gauge sensor is a ground the water temp sensor with a single wire uses the engine ground to drive the sensor up so the hotter the engine the lower the resistance to ground the more the ground the higher the needle in the temp sensor gauge goes up.
If it goes streight to ground with no delay the wire or sensor is grounded in the 7M book it tells you what sensor resistance displays what on the gauge cluster like 2 ohms shows 280deg 300ohms shows 0 degrees so take a reading with a meter and compare it to the trsm guidline for the 7m engine because its the same specs for the jz gauges and sensors for the water temp gauge.
