Hmm this info is definitely helping me out. In for coming up answers!
So let me get this straight, (I'm also searching right now, so I may find the answer before anything further):
-Using aftermarket gauges for water temp, oil pressure, and boost. I do not need the 7m sender and the coolant gauge sender off the 1jz, because those are for gauges only. BUT the 1jzgte ecu does not look for an oil pressure or oil level signal because those are all gauge/dash related, correct? So the only things I need to worry about that the ECU look for are the MAP sensor, IAT sensor, coolant sensor, Knock sensors, Crank position, 2 Cam positions, O2 sensor, and...? The rest will go with the injectors/igniter/COPs/dash/AC etc, but are not 100% necessary to function (of course injectors and such are...), right? Just checking! ; p
