IJ.;1685492 said:Did the noise change at all?
Poodles;1685578 said:Not bottom end, more than likely valve tick..
AZN MK3;1685620 said:Yea it not the bottom end, but with the valve tick should I be worried about it?
:word8kn:aphxero;1685745 said:dude you have a performance engine swap. How can you not figure out simple stuff?
mecevans;1686438 said:Temp has nothing to do with it either. Even if you use a 0W in tripple digits doesn't mean its thinner. If your oils overheated thicker oil does not fix a damn thing.
mecevans;1686438 said:Most all Toyota's take 5W-30. Unless you can magically make all the oil passages bigger, all you did was decrease flow. Temp has nothing to do with it either. Even if you use a 0W in tripple digits doesn't mean its thinner. If your oils overheated thicker oil does not fix a damn thing.
