Can Confirm it's a 10 ohm 1 watt resistor in the pictures above.
<Professor Farnsworth>But, gather round, i have good news!</Professor Farnsworth>
I can *CONFIRM* that the Toyota Lucida Estima (probably the Previa also) Lamp Failure Module (P/N: 89873-28020) is a DIRECT fitment for ours (ie, plugs right in), guys :yes:
The Select-on-Test resistors will probably need to be changed to whatever values were in yours, but, the upshot is, the PCB is of a much newer design (thicker, better construction), uses standard components and only a single 14 pin DIP ASIC. Have included photo's hither.
