T4 Upgrade - HELP me if you've done it.
Bryan92t
Look for used turbos on Ebay from Garrett, PTE, ITS...
You should find a nice turbo to keep in your budget under those names.
Look in the vendors section, 935motorsports.com has a T4 turbo oil line kit for the 7M.
Or you could just get a bolt-on turbo for the 7M.
Search button is your friend.
Xtreme
138
Lebanon, OR
if youre only going for 400 hp. just get an upgraded ct, that is relatively inexpensive, as well as eliminating oil line mods, a new WG, exhaust and intake pipe.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
935's t3 and t4 oil line kit is overpriced by the looks of what you get. Price it out from summit's online store and check what I mean.
eri
siman
Lifetime Ban
Murfreesboro, TN
Do not spend $400 on an "upgraded" CT26. Its destined for failure! Look how long the average life span of an upgraded CT is......since its a small shaft design they just break under heavly load ( boost ).
If you already have $400 just save up another $400 and buy a nice turbonetics T4/T04B-P trim......exhaust A/R should stay around .60-.80(max).
That will EASILY flow upwards of 550-600hp with your current insurance ( mods )....but going with the route I personally am going to hit ( 400whp)....you could hit 400hp on the dyno untuned...which of course is a big no no...but LOL 400 actually is EASY to hit with a new turbo set up.
I see that your local too! Have we met before?
SimpleIcon hit me up in a pm. I got some nice info.
-Jonathan Mann
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
If you are looking for 500 hp, then a good alternative would be a CT housing around a GT40 comp, with a dual ceramic ball bearing cartridge. It's exotic, but quick spooling (so I've heard)and will flow 500-550whp with supporting fuel and tuned. This guy builds quality, and can tell you more about it: Kent@ Turbochargersystems.com go look at the site, and give him a call or e-mail him. He knows his stuff.
Tom
Dziuggy
eurotrash
san francisco, ca
dziuggy.com
btw oil lines, jblmk3 sells oil return block flange with AN-10 adapter on it around $3X. any performance shop sells steel braded lines + any an adapters you need should run you under a hundred to do the lines
