T06 turbo
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Hey to all you Turbo guy's...
I have a N/A that needs more power and i seen a turbo upgrade kit for your 7mgte's, i want to bolt it on to my N/A, along with a ECU, harness from a turbo, injectors ect.
My question is Do any of you know any info on this Turbo?
group a supra
SPAWNING AN INTERCEPTOR
a little more of a description and we might be able to help like a link to the kit if you can
figgie
Twin Cities, Minnesot-ah
that is not a td06,
the GREDDY kit is a TD06 turbo. Spools very nicely. I used to run one and now Bcg04 is running it.
as for the ar housing
.6 is tiny!!!
if it was 1.6 that would be huge but .6 A/R? That is a useable turbo. Though a bit on the smaller side (t04b).
group a supra
the bigger the housing the bigger the a/r in basic terms and not wishing to get complicated on you that means it needs more exhaust gases to fill the housing and make it spool up hence making it less responsive and creating lag
that is the as basic as i can think of explanation if your still not sure just ask
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Alright cool... A/R is a ratio! So if the a/r (0.60) is small on the t04b, should i look at other kits? Or will this kit get me what im looking for... about 300hp!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
group a supra said:
if anyone diagrees with me on the exhaust housing size please say maybe my eyes are tired but it does look a little on the large side compared to the cold sides a/r .60
Yah the exhaust side is massive compared to the cold side! That means turbo lag... doesnt it?
Supracentral
10
I agree, the "T04b ar.60 turbo charger" refers to the cold side A/R.
The hot side is likely over 1.0 and would be a lag monster. This is likley just like most e-Bay turbos with diesel sized exhaust housings...
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
So.... What do you guy's think, should i stay away from this kit or will it work out fine?
Because the price is right!
