Is it still the stock ECU? Kinda cool that it runs like this.. lol. Wonder how your performance is in comparison. (no boost, but the engines still have boogie to them)
295cc/440ccjdmfreak;1917588 said:Does anyone know if there is a difference between n/a and turbo injectors?
Sent from my DROID RAZR using Tapatalk 2
What you're doing is .....jdmfreak;1918067 said:Evidently what I am doing isn't very interesting lol
IJ.;1918072 said:NA Intake has the ACIS valve, not really sure how it's going to act under positive pressure.
IJ.;1918074 said:I meant what you're doing IS interesting... you aren't<jk>
So you decided to not use the Turbo with an open gate?jdmfreak;1918076 said:I got a na exhaust manifold so I shouldn't be getting any positive pressure Without a turbo
I am using the turbo intake manifold because I didn't want to relocate my coil packs.... Just not sure if using the na manifold would give me any noticeable power Increase to make it worth it
or if the throttle body from the na would cause any problems due to the fact that it's not matched to the maf sensor and injectors (excuse my ignorance searching didn't turn up anything)
