Supra Vs Supra (7M vs 1JZ) RESULTS IN VIDEO Pg.21 Post #209
87supraguy
808
Tucson, az
we'll be making a few more runs on the 11th i believe. they have test and tune again. hopefully i have my wastegate issue resolved if not it will be run what you brung again. i really want to practice my RT.
Turbo Habanero
4,229
Tucson,AZ
Yeah i will not be turning up the boost i'm already leaning out lol.
But maybe ill have my exhaust done by then. Also see what i can do about tags on my car lol
87supraguy
808
Tucson, az
turbo habanero;1800493 said:
yeah i will not be turning up the boost i'm already leaning out lol.
my plate......??
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Your 60ft needs the work most...
Turbo Habanero
4,229
Tucson,AZ
supranasty;1800544 said:
He's gonna learn your tricks be careful . That was close.lol
Lol that's cool I want him to do well and see what that beast of a car can do.
I'm excited to see what happens with my car its at the exhaust shop right now I put in a 3inch high flow cat and a 3inch elbow on so its gonna be full 3inch now.
Do you think ill notice a difference?
Turbo Habanero
4,229
Tucson,AZ
So i got the car back and it feels different but idk if its a good difference boost is lower now and i have a exhaust leak between downpipe and Elbow but it's because i didn't provide the gasket for them..
Any idea's where to get a that gasket ?
Also could the exhaust leak cause my Vacuum to read different ? Before it read 14 at idle 20-22 while driving now its 12@ idle and 18 driving...
I had a 3inch High flow cat installed and a 3inch elbow
before it had stock elbow and just a straight pipe.
IBoughtASupra
4,455
Queens, NY
An exhaust leak pre-turbo is never a good thing. Any leak after the turbine/downpipe is just a nuisance.
The vacuum reading could be a leak? Have you done a test to make sure there are no leaks?
Turbo Habanero
4,229
Tucson,AZ
Yeah i dont think i have leaks Pre turbo just between the elbow and downpipe. I have one solid exhaust its all welded except from the elbow to the downpipe. And you can here and feel the air coming out lol.
It only just changed after i got it back from the shop. So not yet
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Screw the CAT, Run The Muffler...Use that money for the Lex/550 mod.
You can Make a gasket yourself. Autozone or PepBoys sell Gasket material with metal lining for exhaust.
Turbo Habanero
4,229
Tucson,AZ
I have the Lexus/560cc mod :) using evo 560's I had the Cat put in for Emissions.
Would this work? it also has the flange so i can make my own Downpipe... Do you think it willl bold up to the 3inch elbow?
http://www.ebay.com/itm/3-BOLTS-3-I...bo&vxp=mtr&hash=item2a18f3d25f#ht_3417wt_1185
mecevans
1,295
M-bay, cali
You loose what 5% of total power with a highflow CAT? Telling someone to remove safety or emissions equipment is irresponsible and just plain stupid. :nono:
