jdub;1142739 said:You told me 5 quarts for the flush. I'm done with this.
If my dipstick says completely no oil, then I have to fill it back up with 5 quarts. Same thing as if I do a flush, no oil in the engine. Fill it up.
IJ.;1142620 said:![]()
<jk>
jdub;1142746 said:You're with the crowd you belong with...you'll get all the help you'll need
SupraCool;1142744 said:If my dipstick says completely no oil, then I have to fill it back up with 5 quarts. Same thing as if I do a flush, no oil in the engine. Fill it up.
skee1234;1142450 said:i have same thing just on cyl#2 mine is constaint up front but cant here at high rpm tho and mine only comes on after the motor warms up a bit
SupraCool;1142562 said:The noise popped its head up one day when I was speeding on the freeway. This whole thing has really confused the crap out of me.
I pulled up to a red light after I got off the freeway. I was sitting there, and then all of a sudden I heard a sputter and the car just died at idle. I checked my oil and it said I had none.
Which doesn't make sense at all because I just got doing an oil flush 2 weeks prior to that incident.
It can't be RK because the noise would be consistent with higher rpms, but its not. The noise goes on and off.
gaboonviper85;1142841 said:take it easy jdub....not only are we confused but I think he confuses himself...not everyone is as flawless as you keep in mind..
figgie;1142972 said:Also checked oil and had none? All it takes is ONE time for the rod knock to come in. And it will not start as heaven and high hell hammer to block sound. I have heard it were it sounds like valves out of adjustment but as the hours on the motors tallied up, the Rod knock got worse and worse until it finally did the hammer on block sound.
BHG? Nope. You got Rod knock. There is no question about it.
