supra cranks but no start, please help
___toyota7mgte___
19
colorado,USA
Hi everyone, my 89 5-speed 7mgte wont start. I have spark, and fuel pressure but no injector pluse. I have changed the CPS, injectors resistor and, ECU. I have also checked the wiring from ECU to resistor it all checks out. When the resistor is pluged in, i have resistance in both sides of the injector plug. When I crank the engine it starts for about 2-5 sec. then dies. it feels like the cold start injector is the only one that works.
Please help!!!
Bishop92t
773
USA
www.ma70.com
Check engine error codes. Ensure your ECU grounds are connected. What was the last thing you did to the car since it last ran?
shaeff
Kurt is FTMFW x2!!!!
10
Around
and for shits and giggles, check the 7.5A IGN fuse in the driver's side fuse box behind the kick panel. :)
-shaeff
___toyota7mgte___
19
colorado,USA
my error codes were 21,52. the last thing i did was tried to fix the sheilded wire on the O2 sensor, i ran another sheilded wire from the computer to the O2 sensor and grounded the sheilded part. I tried to fire it up, and it wouldn't start. I took off all the stuff that I did, and it still wouldn't start...
___toyota7mgte___
19
colorado,USA
-shaeff
I didn't check that fuse, because i thought it was only for the ignition switch. But I will certainly do that, and if that's what was wrong with it, then I deserve to be kicked in the head...:icon_conf
___toyota7mgte___
19
colorado,USA
MDCmotorsports said:
They should have brass lugs on them attached to the back of the intake or under the intake. They are a total of 4 wires, pair in 2's.
those bunch of wires are hooked up. the car ran for about 2 week after i build my engine sence then i only touched the harrness at the ECU and over the cams. after building my engine i couldnt pass the smog test. i tired to run another wire for the O2 due to the 21 error code and she stopped starting.
___toyota7mgte___
19
colorado,USA
So what do i do when i have spark at the coils but no injector pulse, all grounds are hooked up (i even have a engine ground kit). I checked the CPS with a ohm meter and it shows change in position when I spin it.
___toyota7mgte___
19
colorado,USA
Jetjock,
___toyota7mgte___
19
colorado,USA
Jetjock, The + side of the injector circuit is the 3 wires(white, white-blue, white-red )at the plug to the ECU, right?
If so, I checked the 3 wires from ecu to the injector plugs. now another thing, when I ohm tested the 3 wires from ecu to plugs I had resistance at both sides of the plugs, is that normal? and only if the resistor is pluged in.
IHI-RHC7
"The Boss"
Oregon
To clarify, the positive connection is in the round four wire connector on the driver's sode fender. ;)
8,897
If it all checked out, it would start.
Don't make assumptions when trying to diagnose a problem. You can not skip steps in the diagnostic flow charts.
