Lots of misconceptions to twincharging here, so I'll try to clear up a couple things.
Twincharging (aka compound supercharging) works on a couple simple principles.
Super or turbo charger, they work the same - take X starting pressure, and compress it to Y boost pressure.   Y/X = Pressure ratio.   All compressors are most efficient at certain pressure ratios.   Roots blowers (like the eaton) are most efficient at low pressure ratios (say, up to 1.5pr)
Ok, so have that supercharger feeding your NA motor.   1.5Pr * 14.7psi (1 atm) - 14.7 (the outside pressure) = 7.35psi of boost.
Now, let's have a turbo feeding that supercharger.   Also at 1.5pr.   Now, the turbo is the one actually seeing the outside pressure (inlet pressure), so the turbo is actually producing 7.35psi of boost.    That pressurized air is sent to the supercharger.   Now what does the supercharger see?
The supercharger sees an absolute inlet pressure of 22.05psi.   22.05 * 1.05 = 33.075 absolute pressure.  Aka 18.375psi of pressure in the intake manifold.
(this is just the explanation.   If you want to know total boost in the system, just multiply the pressure ratios of each charger)
Now, that was basically 7psi from the turbo, and 7psi from the blower.   Makes about 18.4psi total.
The downside, is the Eaton supercharger will work MUCH harder to flow in these denser atmospheres.   You are best to run 5-6psi from the supercharger, and use a higher pressure ratio on the on the turbo.
The scary thing is, what if you run say... 20psi (2.36pr) from the turbo - and 7 psi on the supercharger (1.48pr).   51.3psi of manifold pressure.   And it is EASILY done.
Why do you think I'm all happy about twincharging the wife's Ion?   :naughty:
