Stretch's Digidash thread
N
NDBoost
Guest
holy hell this is coming along quite well. This is definitely going to encourage more people to try this.
I think its safe to say you might be holding the first LHD Digi Dash Conversion in a Mark3 supra :)
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
I am expecting a full write-up or sale of your services to do this for other members. :) Much respect for doing this and keeping the MKIII owers interisted in the digidash.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I would be interested in purchasing a full digi dash mos def.
Obviously, it wouldn't be cheap, but I think it'd be worthit.
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
hey man.. just a thought. if you can figre out a place to stuff the board as it is now, you could just send a bunch of tiny wires from the pin holes on the board to the pins of the screen. that way you wouldnt have to re do the WHOLE thing. you could cut a slit in the back of the plastic to slip the wires through and have the electronics mounted on the reverse side maybe?
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
:icon_cool
What's happening is the screen is being attached to a regular board, only as large as the screen tho so as not to take up un-necessary space. Then, we're gona run wires from the original pin holes to the new board to each corresponding hole for that particular leg. Not hard at all, just time consuming. It's called sandwiching, since the transfer board will end up sandwiched between the original board and the lcd screen. Sure, there are other ways of making this board fit into the cluster, but they are much harder, AND this way will give a factory fit/finish which will basically allow it to drop right in perfectly!
On another note, I test-fitted the smallest board today and boy was that a good idea! I had to cut away lots of the fiberglass I had put there ahahaa. It fits correctly now, but I have to re-glass some areas for it to be contained again. Oh well, I guess I was naive to think it would fit perfect the first try. Sorry no pics either, my camera lost all its juice.
eric
Stretch
Toronto, Ontario
Yeah, it's a hell of a lot of effort for such a small result, considering it came stock on thousands of other supras. I only wish Toyota would have made it for the LHD to begine with, then I would have just bought one from them.
eric
Stretch
Toronto, Ontario
Hold up guys, it takes time for these things. Both my dad and myself have been busy this week. Me with more work than usual, and him with work as usual :icon_razz . I'll be doing more work on it next week, so just sit tight damn it!
eric
Stretch
Toronto, Ontario
Here's a weekend update for you guys. I got a single pic. It's the diagram showing the side view of the old circuit board and the new design so that I can fit it correctly into the right side of the dash. I only gain 12 millimetres during the conversion on this side, so it'll be incredibly easier compared to the left side where i had to add a couple inches ahahaa. On with the pic!
eric
