ok checked all fuses and jumped efi relay still no check engine light and replaced builb. so pulled key ignition wires witch were all hacket and slots 5 and 7 are making contact when in lock possion is this norm
I6Boost;1593247 said:If so when you turn your key to acc i believe can you hear
your fuel pump kick on?
mkiiichip;1593271 said:Wrong. The pump does not run until there is an rpm signal, sent to the ecu.
To the OP, are you having a no crank or no start issue?
Do the dash lights come on with the key? Which ones come on?
