ok i got the motor in today and started it up it ran ok for a minute and idles fine till i took it off the jack stands now it will start and run for a few seconds but at a really rough idle. i checked all my grounds and my electrical connections every thing is hooked up. some of the vacuum lines i can't figure out where they go, like there is a line coming off the vacuum line deal that bolts under the intake it did not have any vacuum to it. the other ones are hooked up the bypass i can't figure out where it hooks up. the egr lines are hooked up my knock sensors are hooked up if i hold the gas and it gets to 2000 rpms it evens out. but if i take my foot off the gas it won't idle it just dies. now it is bored .040 over but stock style pistons. i moved it out of the garage and it dogs down until i get the rpms up i just don't know i'm thinking vacuum leaks but i can't figure out where all the lines go also a line under the intake has some kind of filter on it and a rubber deal around the conection maybe thats it i just need some help thanks for any pointers. ohh and no check engine lights are on.
