tsuper92;1109638 said:i'm not sure i follow you guy's with this pedal stop.do you guy's think putting more play in the pedal will help.i probably can't add to much more play without making it hard to go in gear.sorry for the thread jack,i've never heard about this before.thanks for the replie's and input on this.
I had this issue of over travel with my OSGiken twin, they only need a small amount of throw for a clean release.
I considered adding a pedal stop but took the lazy option and adjusted the Clutch pedal lower to the floor so it acted as the stop then adjusted the brake pedal to match it's height.
End of problem.
