2jzmk3
Guest
As most of you know Spec is releasing the twin disk for the 7mgte very soon.
We will be taking Pre-Orders if anyone is interested in getting this setup for there car. We at Titan Motorsports are the exclusive dealer for this part.
There will be 4 different variations of the same clutch available.
820ft lbs
1100ft lbs
1200ft lbs
1400 ft lbs
The Spec clutch was a well thought out unit. This kit converts the unit from pull to push. It is a puck clutch set-up with 1 disk that is sprung and 1 that isn't along with a floater plate. The towers are different from other multi discs in that they are part of the pressure plate and not the flywheel. It seems that this would be a superior design as they would be less prone to seizing the floater to the towers. The floater plate is a little noisy when clutch pedal is depressed but that is what you get when you have HP goals like this and you need a clutch such as this. The throwout bearing and the slave cylinder are one piece that slides over the input shaft of the transmission. No modification is needed to install..
Thanks to Duane for the write up and pics.
Anyone one looking to get added to the list email or pm me.
Sean@titanmotorsports.com
820ft lbs
1100ft lbs
1200ft lbs
1400 ft lbs
