Spec Super Twin Disk Clutch for 7M-GTE
2jzmk3
Guest
As most of you know Spec is releasing the twin disk for the 7mgte very soon.
We will be taking Pre-Orders if anyone is interested in getting this setup for there car. We at Titan Motorsports are the exclusive dealer for this part.
There will be 4 different variations of the same clutch available.
820ft lbs
1100ft lbs
1200ft lbs
1400 ft lbs
The Spec clutch was a well thought out unit. This kit converts the unit from pull to push. It is a puck clutch set-up with 1 disk that is sprung and 1 that isn't along with a floater plate. The towers are different from other multi discs in that they are part of the pressure plate and not the flywheel. It seems that this would be a superior design as they would be less prone to seizing the floater to the towers. The floater plate is a little noisy when clutch pedal is depressed but that is what you get when you have HP goals like this and you need a clutch such as this. The throwout bearing and the slave cylinder are one piece that slides over the input shaft of the transmission. No modification is needed to install..
Thanks to Duane for the write up and pics.
Anyone one looking to get added to the list email or pm me.
Sean@titanmotorsports.com
Spec&
2jzmk3
Guest
no remarks. there was a bunch of you interested a few weeks ago...
1700 ... 850 /1100
1790... 1200/ 1400
tissimo
Stock is boring :(
Melbourne, FL
1700 ... 850 /1100
1790... 1200/ 1400
those are the prices?
Thats very resonable!
you know mkiii owners.. all talk, but when its time to put up the money, they scatter, lol.. i am guilty of it too though :icon_redf
Is there any thoughts on making these for the jz guys?
Noah, I already know I'll never make enough torque to need one of these...........:biglaugh:
suprarich
Guest
Nov 9, 2005
2,187
ohio
Sean - You know I will be buying 5 or 6 of them. I have several customers that want them already overseas.
themadhatter
760
Vegas
holy shit that thing is crazy looking!!! So where would you use somthing like this at just the track or is it friendly anuff to use on th street? I know i've used a 6puck unsprung clutch n my old car and god i hated it. You could only have the clutch engaged of disengaged there was no inbetween so is this an thing like that?
Dec 3, 2003
6,653
Canada
820ft lbs
1100ft lbs
1200ft lbs
1400 ft lbs
The Spec clutch was a well thought out unit. This kit converts the unit from pull to push. It is a puck clutch set-up with 1 disk that is sprung and 1 that isnt't along with a floater plate. The towers are different from other multi discs in that they are part of the pressure plate and not the flywheel. It seems that this would be a superior design as they would be less prone to seizing the floater to the towers. The floater plate is a little noisy when clutch pedal is depressed but that is what you get when you have HP goals like this and you need a clutch such as this. The throwout bearing and the slave cylinder are one piece that slides over the input shaft of the transmission. No modification is needed to install..
No problem :icon_bigg
noah89t;905622 said:
very nice looking clutch, can the wilwood master be bought separately?
I doubt it. They sell this as a kit but you can ask Titan.
2jzmk3
Guest
Slow66;905604 said:
I'll pick one up for my new street supra.....you need $$ down??
yea if you want to leave a deposit i can get it on the way. i dont need all the money up front, but i would like to get them going on making them, so let me know.
yes, those are in the works also..
no, this is a street/strip clutch, the clutch pedal will be as soft as stock, since it uses a hyralic release bearing as aoposed to a clutch fork..
figgie;905785 said:
Sean are those the prices $1700/$1790??? If so .... :)
yes those are the prices, i am putting them on the titan site shortly. 1820/1950.
rich you know i have those resevered for you already...
any other questions feel free to ask..
figgie
Twin Cities, Minnesot-ah
bah you guys have
OS Giken, HKS, RPS, and countless other multiplates!!! :p
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Sean, When are the 1jz clutch supposed to be released??? I might need one around spring, It's either this kool spec twin or carbonetics twin.
2jzmk3
Guest
i dont know on the 1/2jz r154 config. we are still working on this one getting mass produced, so i dont think that one will be ready for at least 4-6 months.
