Sound Deadening Weight & Measure!
Chris86.5
102
Leduc AB
i pretty much did the same, thing i took out all the deadener. but I'm putting new stuff in, with the bonus of spraying rock guard in the cab. so when i have my stereo in it it will be SOO nice. and when the stereo isnt playing, there will be little noise
catback
bitterville
silent_sniper said:
THERE IS HARDLY ANY ROAD NOISE all this talk about lots of road noise with sound deadening is myth put carpet back in and most people didnt even notice the incress and those who did were the ones who helped me pull the stuff out.
worth it
to me yes because i need to take it out so i can FG my sub into my back seat area and the noise difrence is so small its worth the weight savings
for those looking for the whole stock thing drive with someone whos done it and make the opinon for your selfs
how much will the sub box weigh:icon_razz
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i took out all my sound dead gutted the carpet too from fome
i took out so much stuff out of the 86.5 it's not funny mics wireing remade light white front bumper the freakign list goes on
my record is 2980
so 500 plsu pound loose is worth it to me heheheh
swaq
posts++;
May 24, 2005
1,351
Oregon -> Arizona
www.SwaqValley.com
ForcedTorque said:
I do admire the fact that you did the actual weighing of the parts, instead of guestimating like most weight savers do. I've seen the weight deadening material guesstimated at 200 pounds before. Maybe you will discourage someone else from doing this by showing a true weight.
I agree. Very good info. I personally wouldn't do this unless I was building a dedicated track car (which is definitely not what I have a Supra for).
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
hopefully not 55 lbs
oh i should mention that mine was soaking wet and there was a shitload of surfuse rust under it. which was another reason i took it out
89Turbo
804
Portland
my record is 2980
Pm me a list please. was this done with an empty tank of gas also?
Dirgle
Conjurer of Boost
Pauma Valley, CA
Brewster said:
That seems totally not worth it to me.
Some things are just beyond me i guess. I didn't buy a supra just so I could tear things out of it to save a 10th of a second here or there. If I was building a track car maybe, But not a street car, and not the supra.
You say you don't notice the noise but I'm sure I would, those kind of things bug the hell out of me, I will change tires if they are too noisy.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
a list ummm think of every think that is heavy that can be replaced and repalced it with some thing lighter or got rid of completely
lets put it this way i have no heater in my car nore hood latch i do still retaint the stock to certon dagrea cetp all the branceing is cut out withc makes it much lighter nore do i ahve an e brake the list goes on
i would love to amke list but i ahve done so muhc and stuff that i forget alot fo it
when you have an idea to start to remove weight all weight counts it adds up over time
oh yae on my blisten on lower perch and eb spring was about 1 ich lower then stock basicl thus is the reson why i had to go coil overs so i choudl lower it and regain my cars handleing back caus eof all teh weight i removed
you be suprice on how much you cars handleign get distrubed just by repalce you seast wiht really light ones get very under streery
so taken to much weight out fo your car can make it wores
any wyas as in the lost if i ahve the spare time i might go ahead and try to remeber it all
but on this build i have added more weight then last time as how much ti will be i am not sure
to answer thsi qestion it was not fully emtly but close this was the level i used to auto x with and drag
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Bathory said:
Pray tell, what will removing the sound deadener cause to rattle? The carpet against the floorboards? I dont think so.
Please read carefully before you post something dumb like that ;). We were discussing subs between those two posts, nothing about, "removing the sound deadning material will cause the car to rattle". Ever heard a car from the outside with subs blasting and the rear end rattling? Ever laid down the back seats just to hear it more? Yeah, glad we got that cleared up now ;).
lagged
1991 1JZ
new rochelle
where did you get your car from?
sounds like a flood car....
Bathory
34
Massachusetts
Actualy, what you said was "More thump to overpower the rattling ;)" that implies turning up the radio to overcome the rattling of the car (presumably from removing the sound deadener) If the "THUMP" is what is causing the rattling your talking about then how the fuck is MORE thump gonna overpower it? And more to the point, my comment was directed to all the knuckleheads that think the car becomes intolerably loud.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Post, #4 refers to buying an amp to make the radio louder. Once you get enough "thump" you don't hear jack shit except for the "thump". Ask me how I know ;). You presume, or assume incorrectly, but, it's all gravy. I understand where you're coming from with the knucklehead comment ;).
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
UNLESS you want to replace it with the better stuff that was mentioned and make it quieter than it was stock... otherwise it seems like too much work...not really a sound issue, while i think it would cause more noise i'm not sure...but i'm pretty sure its a lot of work!!
what about heat? does this stuf shield heat?
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
haha no i thing its because my hatch leaks and the water drains right in to were my passenger seat was and collected there i say this because only the passenger side had rust
