Son of a bitc*
huntin5L
Niles, IL
are the wires easy to get too when this panel is removed, i really wouldn't like to disable it, but i wouldn't even know what the hell to replace if i wanted to keep it
shaeff
Kurt is FTMFW x2!!!!
10
Around
if the starter doesnt work, then chances are it's your alarm. (or a dead starter) but if the alarm goes off, your starter will NOT work.
you could grab the wires for the under hood sensor, and just loop them, but i chose to completely remove the alarm computer. it really wasnt that difficult. once you locate it, just grab a small socket wrench and a couple sockets, and go to town on it. mine came right out. i just removed the under steering wheel trim, and the vent tube that goes across under there. by the way, looping the under hood wires will make the theft deterrant ECU think that a door, or your hood is open, thus preventing it from arming itself when you lock the car.
there is a link in the link i posted, as jimi stated, that shows where the theft deterrant ECU is.
-shaeff
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
yeah, but if you disconnect it, you have to be sure to ground the start disable wire from the plug. It is pin 13 and is a blue with orange strip wire. if that is not grounded, the car will not start.
that is how the alarm disables the starter if it is triggered. it takes away the ground connection form the starter relay which is that blue w/ orange wire.
The easiest way to do it is to unplug it and put a jumper in the plug between the pin 13 (blue w/ orange wire) and pin 5 (white w/ Black stripe wire). the pin 5 white w/ black stripe wire already goes to ground.
huntin5L
Niles, IL
Good deal ill try this, i just hope it isn't a pain in the ass to get to the module. Ill attempt it tomorrow. Thanks a lot guys.
huntin5L
Niles, IL
Alright boys im attempting this in a little bit after i can get my battery charged in my Z. Damn thing had no juice so i couldn't start it.
huntin5L
Niles, IL
tried unhooking the clip from the theft detterent system and i extended the blue and orange stripe, grounded it and tried starting, nothing. Also, tried when it was connected to the system and still nothing. Im out of options here, what do i do?
huntin5L
Niles, IL
Yeah but i know my alarm is fubar unless something in the starter is f-ing it up, i know i had this problem where the damn car wouldn't start so i took a hair dryer to the cps wires because the wires were so hard and mind you it was like 12 degrees outside and after the hair dryer i moved the cps wires and it started
ma70t
7mgte-s
Jun 7, 2005
141
va
you can bypass the starter i did it to mine and it work i had the same problem
the alarm dont disarm it just stop the horn and light from going of but the starter kill is still on but i just bypass the starter with a swtich and it works fine i only use the switch when my starter wont start
shaeff
10
Around
to bypass the starter kill is in the link i provided. AND cjsupra said the same thing, too. re-read the previous posts. :)
-shaeff
ma70t
7mgte-s
Jun 7, 2005
141
va
run one b+ wire to the switch and then run the other end to your starter solenoid and the other end to the switch but make sure that the switch is on the off then flip the switch everytime that your supra will not start cause what will happen is that the starter will crank the motor every time the switch is flip to on but once your car start you need to turn it off or else your starter will die for good ok
mkiiSupraMan18
Needs a new username...
United States
I couldn't pull start my car (with a bug-ass diesel truck)
when the alarm was tripped.... How the hell do you manage to push start it? we pulled it all around the target parking lot in 1st 2nd and 3rd gear... Then I call MDC with a "WTF?" and he tells me to lock/unlock the door, and bam.... fires right up.
I'd be checking fuses and stuff too... those "wire" fuses in the fuse box under the hood. But I don't know anything, i drive a mkII. :nono: just trying to help out.
huntin5L
Niles, IL
Okay ill reread shaeff :) I pushed mine myself and jumped in and popped the clutch in first and it starts right up, most of the time. The other day i pushed it for a block and a half. I thought i was gonna die.
huntin5L
Niles, IL
So far its the starter that was filled with oil, so the starter, and starter relay need replacing. I don't know about the alarm yet.
