OK, sorry about never getting some pictures up of the final product. I have a bunch in this post.
My driver's side ballast still doesn't light on the first try. I should be getting new ballasts around the 10th of December when they get the redesigned ones in.
The only thing that I have noticed is that the high beam indicator does not come on any more, and when I have the fog lights on and turn on the high beams the high beams will not turn off until the fog lights are turned off. I assume this is because there are no actual headlights plugged into the car. If anyone knows how to get around this please let me know.
Here they are, there's a lot of them. (Sorry they aren't of the best quality) Sorry that the lenses are dirty, I drove the car in the rain the other day to make sure that the lights were water tight. The good thing is that they are water tight, I took three balloons on each side and cut the tops off and used them to make a sort of rubber cap on the back of each light. I do get a small amount of fogging in in the corners of the lights, but this doesn't bother me since they are pop up headlights.
Here they are in the car.
Here are a few pictures of the actual cutoff upclose. I think it looks really good.
Some pictures of the lights or looking at the car.
Trying to get a picture of the color flicker.
Some output pics looking at the garage. The lights arent crooked, it is the driveway and garage door.
High beam pattern
Looking at the back of a Honda Odyssey while waiting at a light that takes forever.
Here are a few from around the neighborhood. The pictures are in pairs, the top one is low beam with the bottom one in the pair being high beam.
The dot in the middle of the picture is a Lexus in someones driveway. In real life you can actually see the car with the low beams on was you come down the road. Just for a comparison even with my Hellas with the high beams on I could not see this Lexus.
In this set you can really see the house at the end of the road with the high beams on.
I think this set came out the best. If you look at the big tree you can really see the difference in the high beams.
This is definitely one of the best things I have done to the car. This gives the performance of a modern headlight combined with the aesthetics of pop up headlights.
If anyone has any questions or comments feel free to post them.
High beam pattern
