Some questions from a noob plz reply
SUPRASAM
aus perth
gday all, im new to thhis forum n have owned a mk3 86.5 7mge 5spd for bout a week now, anyway i have some questions...
1) roughly what should my car pull down the quater mile being stock with a k&n filter?
2) what things could i remove or change on my supra to lose weight? (i know the obvious spare wheel back seets)
3) if i was going to wack on a turbo, do i need to strenthen the engine in anyway e.g forged pistons etc...
thanks guys
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
#1
15.5-16
#2
depeneds if its gonna be driven on the street. (or if u don't care if u die in a crash or not... lol)
u can remove the bumper supports... alot of weight there. but if u crash, u die
rear seat, passenger seat, interior, sound dampening material,spair tire.
Light weight rims helps alot too
#3 if u want to make good power, yes.
or swap for a 7MGTE
SUPRASAM
aus perth
ok kool,
thanxs silvergsx623, what exactly is sound dampening material??? and how diffucult is it to remove bumper supoorts and what do they do...
cheers
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
sound deadining is the crap under the carpet. it looks like tar that was melted and poured on the floor of the car. use a small hammer and hit it lightly a few timesand it should come up pretty easy. saves you 42lbs. bumper supports are the steel reinforcers behind the bumpers.
SUPRASAM
aus perth
thanx eviltwin,
in a couple weeks i will be taking the supra down to the local dragstrip to see what it can do as it is, it has the stock LSD but sometimes one leggers... when i do my burnout before the race is there any method i should use to light em up or anything, also will it be likely to one legger when i pull my burnout???
cheers
supraman7mgte
Shut up,bitch!!
Sunny California
I'd keep the bumper reinforcment up front,it's designed for safety. But you can remove the carpeting,replace the drivers seat w/ a race version,take out the cruise control,and whatever you think might be holding you down
