Mike - were you able to find a compressor map for your Boss Turbo?
What intercooler and how much CFM capacity did Cartech advise you go to?
tisk tisk for being lazy ... i say to hell w/ the cartech unit.. time for 95mm tb + ffi + 3" pipes + LARGE IC :naughty: :biglaugh:malloynx said:I called cartech today and i was advised to go to a bigger unit all together. i was told that even if i welded on 2.5 inlet and oulet that the intercooler itself is not up to the task.
i really didn't want to go this route, but i need to get this fixed. like i said; the car feels great, but in the upper rpms the car is running out of steam.
malloynx said:i wasn't able to find a compressor map; however i was told that my turbo flows 75lb./hr. i really don't nkow what that means. also cartech says they have nothing for me with the power i'm making. i think the guy said an 18 inch long intercooler would work, but it need to be 3.5inches think.
malloynx said:thanks for all the info guys. it's much apperiated. i will say this... the bolt-on turbo is staying. i going to workout this intercooler setup and go from there. One step at a time.
jdub, thanks for the technical data. i know people that TIG. you think i should try that route?
malloynx said:i'm running the maft-pro. also i want to add that my lower intercooler pipe is only 2inches
imagine the possibilites
CryoSlash said:yes it is! for the power you are at, running a 2 inch is no better then the stock ic. well anything is better then the stock IC but you get my point. Justin is right here, it is only as good as its restriction. Time to go 3 inch buddy
