You sound just like me right now bud. I have a 86 supra 1jz at my shop that I am working on for a buddie. But his car idles well (13afr)(30psi at the gauge) but once revved past 3k or so it spits and sputters and leans out horribly (in the 20's!), then the ecu shuts me down back to idle. I have done all the same tests as you. Have you checked continuity with your injectors? This supra I am working on came in to me FIRST running horribly rich and sounds exactly like your problem at FIRST, I rewired his entire wiring harness because there were a tons of breaks right before the plugs...that problem was solved. Now my problem is, it idles perfectly, but wont rev past 3k rpms spitting and sputtering and leaning out horribly unless I unplug the map.
It seems like you done all the right things, I would start shooting for a new ecu as thats what im thinking about doing as well. Because the map sensor, coolant temp sensor, tps, air intake temp sensor all share the same power, I checked and they all have power/ground/Signal...And signal going to ecu as well with continuity!
Recalibrated the tps with a new one, same thing.
But as soon as I unplug my map, the car runs rich in the 10s. I can free rev it to redline and sounds 20x better, but can't drive it worth a damn because as soon as it reads boost it cuts down.
I have replaced the coils, cam sensors, tps, fuel pump, injectors (4x), ignitor, and does the same thing. Timing is TDC and perfect.
Mods are:
-1jz aristo
-440cc injectors
-Single turbo 70mm
- Aeromotive regulator
-Walboro pump (12V)
-etc
I'll keep you updated on my buddies car and hopefully we may have the same issue.
-Lee @ Endless Performance
