depends on the connection im using. If subject to flex and stress I prefer crimps with heat shrink. In most cases though I prefer solder with heat shrink extending at least one inch down from each end of the exposed portion.
Poodles said:
isnms said:I'm going to install my Lex and 550's this weekend when I replace my intake manifold gasket.
Which is best method of splicing in the new injector clips?
Solder or Crimp
dbsupra90 said:you really think 95% of the people on here will buy $100+ adapter clips?
i went down that road, and couldnt sell a single set. i sell the $30 standard clips all day long.
Soldering a terminal is a last resort if the proper crimp tool is not available. Soldering will cause a stress point where the solder wicks up the wire which is likely to cause a fracture. Solder flux can also cause corrosion and may affect the contacts.
The preferred method of securing a wire to a terminal is to use a crimp with NO solder.
The procedures for automotive wire harnesses vary, however, I'll narrowly comment on building a wire harness for a racing car according to the MilSpec guidelines for airplane harnessing. There is almost never, ever a time where soldering is acceptable. When you solder, you create a joint where the wire which is flexible meets with an inflexible joint and eventually, due to vibration, the wire will become fatigued and break. I crimp everything and use a proper strain relief which can be as simple as a glue lined shrink tubing and a small zip tie.
Dr Tweak said:Mil-spec crimps are non-insulated (heat-shrink tubing is used after the connection is made), typically made of tin-plated copper. They come in several sizes and the right crimp must be used for the right size wire. Then the crimping tool, with the matching die is used to make the connection. The tool has a ratcheting mechanism, so EVERY single crimp is made using the same amount of pressure EVERY single time. The ratcheting tool also helps to put more force into the crimp then otherwise possible.
-Doc
agreedp5150 said:Yeah quake I think that goes back to the type of crimp connector used. I do know that on aircraft solder is used very rarely and many things are crimped - just with a different tool and quality connectors
