OneJoeZee said:Colder than you were a few posts ago. In hindsight, your post that the whole thing is zero is incorrect but you were on the right track.
annoyingrob said:(a+b)(a-b) = b(a-b) does not mean (a+b) = b. What you are doing is dividing the first equation by zero (a-b) to give yourself the second equation, which is mathematically incorrect.
And THAT's why this proof is false.
It didn't take abstract algebra in university for nothing![]()
The problem isn't in step 3. The problem is going from step 3 to step 4. You cannot simply take away a factor of (a-b), as you would be dividing by zero.speed dodici said:I don't see where the problem in step 3 is.
(a+b)(a-b) = b(a-b)
(2a)(0)=b(0)
0* anything is 0, so that step has no errors.
On a side note, I love figuring out stuff like this, but I get so freaking frustrated with proofs cause I'm never right! DAMN YOU MATH!
(a+b)(a-b) = b(a-b)
(2a)(0)=b(0)
OneJoeZee said:^Winner.
It really was that simple. You cannot divide by zero. That would cause an undefined solution. Therefore, you could not go any further than step 3. but if you COULD like the fautly proof shows, you would get the remaining steps that follow.
Derk, you were so close. when you were talking about zeros a few posts ago.At least you identified that step 3 is where the problem lies but Rob gave the correct reason why it's not right.
valgekotkas said:If it is 0 that doesn't show, that something is wrong...
OneJoeZee said:The solution is not zero. Read what Rob wrote. Step 3 to 4 shows cancellation by division but it's dividing by zero. That results in an undefined solution, not zero.
Sry, I deleted the post, cause I couldn't rephrase it. lets try... You showed, that something is wrong, but you didn't show why exactly that was wrong. The reason why 0 isnot 2=1.SupraDerk said:If in the middle of the proof you end up with both sides equaling zero... but in the rest of the proof afterwards it shows something else... I think that would show that there's something very wrong...
SupraDerk said:I KNOW THAT!!!
Ah jesus forget it... you don't seem to be understanding
