1st of all - I used the search feature and still have some questions -
Alright- I just replaced my turbo, which was leaking oil through the accordian hose, with one i bought from "Suprafanatic" here in the forums-
After I put it in, i left the car running to check for any leaks- saw nothing wrong-
So i lowered the car and took it for a quick test drive- As soon as i shifted from 1st to 2nd- a huge cloud of smoke came from the right side of my engine bay (the turbo side)-
The smoke would only show up after i'd shift, which seemed kinda weird -
Afterwards, i drove straight home and popped the hood, leaving the motor on, and saw a steady spray of smoke coming from behind my turbo- :cry:
I then checked underneath the motor and saw some oil leaking from the what looked like the corner of the IC next to the oil cooler- Im not to sure where the oils comin from- :1zhelp:
Any ideas? Thanks
and sorry for the essay
oil under IC:
oil between Radiator and IC:
oil on botton portion of Radiator:
Where oil leaks from:
Any ideas? Thanks
oil under IC:
