***SM Member Horsepower List***
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
teamslow;2003555 said:
7m-gte, precision 6765 journal bearing turbo.81A/R 18 psi on pumped gas, JE pistons, Crower rods, port and polish head, 1mm oversized ferrea valves, ATI crank pulley, sethron long runner FFIM w/ 90mm TB, 24x12x4 intercooler w/ 3" piping on cold and side and 2.5" piping on hot side, 3" downpipe and exhaust, ID1000cc injectors, Walbro 400 LPH fuel pump, -6 fuel lines, Aeromotive FPR, stock fuel rail, DH61 igniter, stock coil packs, AEM EMS v1. OS Giken twin disc clutch, Full race built marlin crawler R154 transmission, shaftmasters aluminum driveshaft.
approximately 526whp and 475tq
Something is strange, you should be making more power with all those goodies.
teamslow
158
New Jersey
On your youtube video, you posted 482rwhp and 391rwtq at 17psi. Also, there is a 67mm turbo dyno thread on supraforums and everyone on pump gas made between 470 to 510 rwhp. So I think my numbers are decent. When my tuner told me I made 525rwhp, I told him to stop there because I was more than happy with that power already. He told me he probably could advance the timing a little more but he left it where it was to keep it conservative. And yes the cams are pretty much stock. My cams are regrinds with .010 more lift but have a stock duration.
mytmk3
643
christchurch
My latest.
7mgte
Masterpower T70, 1200cc injectors, dual walbros, link g4 storm ecu, tial 44mm gate, e85(flex fuel so still 410kw on pump)
Edit: forgot to add toda cams 264/272
Sent from my GT-I9300 using Tapatalk
mytmk3
643
christchurch
Should also add im currently number 10 and 16 :) probably should delete my old ones same motor just more fuel and tuning
Doat
2,599
Houston, TX
hahahahah never fail to get a comment about that. I laughed at the DMV when I got the new plates the lady was confused.
te72
Classifieds Moderator
6,619
9
WHYoming
A plate I had ordered for the 89 shortly after I got it:
Wanna guess what happened about a day before the plates showed up? Yeah... don't tempt fate with a Supra. ;)
...but if it's what the DMV gave you without asking, that's beyond awesome.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
finally got my car on a dyno jet and its worthy of the top 10!!!!!!
mods are....
2jz na-t
ffim
hx35 7 blade
tial mvr44 @20psi
lex/550/safc2/afpr
DeMoN2318
572
Arizona
Didnt quite make the list...yet
320whp/330ftlbs @ 11psi
7MGTE, stock internals, stock ct26, non-shimmed WG
BIC DDP, Test Pipe, 3in Catback, Vibrant Performance Muffler
550s, LEX AFM, NEO, Walbro 255, AFPR
2.5in IC piping, Spearco Replica IC, HKS SSQV III BOV
2J coils
mark1987supra
work in progress
May 26, 2008
74
Des Moines
7MGTE, PROEFI, E55, SP61, 25 psi, 1200cc inj., BC 272 cams, Weisco 20 over, Crower rods, Hks Stopper, ARP Head and main studs.
Changed wastegate made 27 psi on old plugs. I don't have a dyno sheet from this visit but also changed the plugs and started making 30psi. Snapped the pinion again and working on changing chasis so not going to hit the dyno in this car anymore.
http://www.youtube.com/watch?v=pyJyCFv1JDc&list=UUE570Jqw0OEqtNY06QqlAOw
emission
1.5JZ powered!
Jun 11, 2005
216
Long Beach, CA
1JZ head with HKS 264 in/ex cams, HKS 2JZ cam gears degree'd, GReddy head gasket.
2JZGE block with 2JZGTE piston, 2JZGTE Rods, (ARP Head bolts, Main bolts & rod bolts)
Driftmotion 14mm top feed fuel rail kit, iD1000cc inj, Walbro 400lph pump, -8 out & -10 in fuel lines, Aeromotive FPR
Driftmotion Fuel injector resistor delete plug
Driftmotion 1JZ T4 twinscroll manifold
Borg Warner EFR 7670 - 1.05 A/R T4 twinscroll (external WG) TiAL 46mm gate
491.5hp 455.7tq at 14psi with boost spike to 15psi - 91 Octane
APEXi Power FC ECU for JZA80 US spec
Tuned on Dynapak in Southern California
Captain
80
NM
7M-GTE 91 octane pump gas
RC 1000's
Weisco pistons .020 over
Eagle rods
Short runner FFIM
GTX4088r w/.85 hot side
TODA 272's not degreed
GSC valve springs
Stock valves
630 hp and 447 ft/lbs ~20psi
The tuner is CAMTuning on Facebook for those of you who do that sort of thing.
