***SM Member Horsepower List***
gixxer750
2jzget comingsoon!
Mississippi
I made 432 whp at tx 2k8 on pump gas boost... lol... Made a good bit more than that before, but I'll have to dig up dyno sheets, as there were no witness's on here
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
gixxer750
2jzget comingsoon!
Mississippi
tx2k8 dyno graph... 15-16 psi according to aem datalogs... t66, FFIM, few other things. 5k rpm early rev limit.
7k rpm should have been 132 in 4th gear. 3.91 gear, 275X45X17 rear tire, 1:1 fourth gear.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
http://www.youtube.com/v/l0bXdtQLEyA
higher hp run was @ 12.99psi,276hp 324tq, but it ran a bit lean in mid range so we dropped down a bit and hit 11.3psi and did 259hp 297tq
power dropped in the top end, i coulda probably hit 300hp without the 2.5" flex section in the hks replica downpipe.
Mods: Rabid chimp 7mgte with mhg, arp head studs. 3" elbow, HKS replica 3" downpipe with 2.5" flex section. 3" test pipe, Tanabe Hyper Medallion Cat Back. Greddy Profec E01. Upper hardpipe with Greddy Type RS bov. K&N cone filter with LIPP adapter. Spec stage 3 clutch.
Is there going to be a 1.5jz section? Please don't put me with those high horsepowered 2jz.........:biglaugh:
topgear
The Thrillseeker.
Jun 4, 2007
80
Tallinn
mods
ARP Pro Series Head Bolts
Clevite Main & Rod Bearings
Wiseco Pistons & Rings - 7MGTE - 84mm Bore, .040 Oversize, 9.0 Comp Ratio
Eagle H Beams 4340 Forged Chromoly Steel Connecting Rods
Fidanza Built To Fly Flywheel
RPS Bronze Stage 5 Clutch Kit (Sprung Disk)
Titan Motorsports Head Gasket (Stopper style), 2.0mm
Toga High Volume Oil Pump
//Powerhouse Stainless Exhaust Manifold
Garret GT40
40mm UnKnown Wastegate
Custom Cooler & Piping
Spearco Intake
Custom 3` Exhaust
PIT Blow off Valve and Flange
Walbro 255lph Fuel Pump
WR Adjustable Fuel Pressure Regulator
RC Engineering 1000cc Injectors
Tein Super Street Suspension
Stop Tech break Pads
AEM
Nick Stonawski
403
Manhattan Beach
Time to UPDATE the 2JZ MK3 LIST!!!! :)
620RWHP 524RWTQ @28psi (100 octane)
475RWHP 435RWTQ @17psi (91 octane)
2JZGTE
GReddy T88-33D
GReddy 720cc Injectors
GReddy Type-CH Wastegate
GReddy Type R Intercooler
GReddy Downpipe
GReddy Intake
GReddy Timing Belt
GReddy Oil Filter Relocation kit
GReddy Profec-B Boost Controller
GReddy Turbo Timer
HKS Cam Gears
HKS Camshafts 264 Intake & Exhaust
HKS Fuel Rail
HKS HiPower Muffler
HKS Super Sequential Blow Off Valve
HKS Twin Power DLI
Danstoy 3" Catback Exhuast
Danstoy Intercooler piping
Danstoy Exhuast Manifold
Exedy Twin Plate Clutch
Exedy Lightened Flywheel
Earls -6 Fuel Lines
Earls Fuel Line Fittings
Earls Dual Fuel Filters
2JZ G-Force ECU w/ No Limiters
1JZ Hydraulic Fan
1JZ Bell Housing
TRD Oil Cap
TRD Radiator cap
Aeromotive Fuel Pressure Regulator
Autometer Fuel Pressure Gauge
BriBano SE Dual Fuel Pumps
Denso Copper Sparks
Optima Yellow Top Battery
Samco Radiator Hoses
Koyo Aluminum Radiator
2jzmk3
Guest
i guess i'll post.. 1037@40psi stilll have some more boost and havent sprayed yet.
SirLoki
129
Fullerton
update to 2jz mk3 list as well, i wanna be there with nick!
2JZGTE motor
AEM Standalone with all the sensors (boost, map, ait, wideband)
HKS T04Z Turbo Kit (turbo, manifold, wastegate, dp, bov)
HKS 264 Cams / Sprockets
HKS Fuel Pressure Regulator
HKS Fuel Rail
Greddy 720cc Injectors
HKS Twin Power
HKS Type S Intercooler
Exedy Twin Plate
XRP 1/2" fuel line / dual feed
SARD 280 lph Fuel Pump (only running 1 pump)
HKS drager exhaust
1Supraholic
69
SoCal
2JZGTE motor
HKS Fuel Rail
HKS Twin Power
Exedy Twin Plate
HKS drager exhaust
way to go, b-boy! ! ! and you too, nick! ! !
isnms
United States of America
Oklahoma
i80.photobucket.com
268hp/299tq, ~13psi, ~11.5A/F,
This was two years ago. I plan to get it on the dyno again when I get my Raptor catback installed :naughty:
Mods:
◊ k&n fipk ◊ cartech ic series 2 ◊ defcon ic hardpipes ◊ bosch 110 & blitz ss ◊ ct26 50trim no clip ◊ becauseican 3"dp w/elbow ◊ 3" high flow cat ◊ 3" cat back ◊ arp head bolts 75 ft/lb ◊ cometic mls hg .074” 84mm ◊ autolite 3923 ◊ spec stage2 clutch ◊ yokohama avs es100 ◊ sogi tems firm override ◊ hks tt ◊ hks evc iv ◊ hks s-afr ◊ zeitronix zt-2 ◊ g-tech pro rr ◊
Since then I have installed:
~15psi, 12A/F
◊ lexus afm ◊ pte 550 injectors ◊ ngk plugs ◊ msd 8.5mm ◊ raptor 3" cat back ◊ ati super damper ◊ fidanza aluminum flywheel ◊ greddy rebic lc cpu-ii ◊
