***SM member 1/4 mi. times list***
One of the mods get your ban stick ready. We've waited very patiently for this alleged ten second run, but now it's time to flex a little muscle. If that doesn't work, we can always beg...............please, please,please,please,please post up the video......................:biglaugh:
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
13.3 @ 106mph :)
7M powered mk3
edit: forgot to add specs
stock engine with 20 thou pistons
46 trim ct (50.9mm comp wheel)
3" exhaust from stock elbow back
Pod filter
9psi
bigger intercooler & 2.5" hardpipes (going about 20 feet LOL)
gixxer750
2jzget comingsoon!
Mississippi
Haven't been to the track yet... but I don't see any reason I won't be able to produce a 10.XX
I've got my suspension worked out, some ET drags, 640 whp, a two step, and will have aem traction control working fairly soon.
Very very possible. I can kinda drive a little too ;)
gixxer750
2jzget comingsoon!
Mississippi
upgradedsupra said:
Where? Car? Mods?
Brookhaven, Mississippi
88 Supra turbo 5 speed
mods:
T66(at 28 psi), AEM EMS, Poly rear bushings, modded traction arms, 2.3 degree positive camber alignment, one piece steel driveshaft, 26X10.5 slicks, working two step with ability to build 15 psi on launch, stock rear struts and springs manually set to full soft(for track only all other times I run kyb's), ACT HD clutch&pp, FFIM, q45, wiseco pistons, stock prepped rods, fuel cell, a1000, welded subframe... thats about all that matters on this.(oh, and car weighs 3144 lbs without me in it.)
joeytvr
112
Louisiana
well if that dude holds together I think you may be there. I now that a 10 sec pass on a 5 speed in the mkiii is going to be a violent shock on the drivetrain. If you happen to get in this area let me know and we can make a trip to the track together. I would love to video some runs for you
What injectors do you run?
BTZ
Burnaby
12.704 @112.58 57 trim ct-26, lex/550, safcII, 5spd on a stock 7m motor with a blown metal head gasket and a cracked head. woot.
Twin 1jz
65
San Juan
Hi guys,
We have a few fast mk3's here. I own a 1986 with an internally stock 1jz with twin k26's and have done 9.48@146 on slick and open exhaust. 9.81@144 with d.o.t. tires and mufflers. Also own a 1985 Corolla with the same set up as the Supra but using less boost and is doing high 8 seconds @ over 150mph. Both have manual transmissions and are street cars. The other project of mine is a gutted 87 with a build 7mgt. My brother has an 89 with 7mgt has done low 11's thru the mufflers on pump gas @ 17psi. Engine has only hks gasket and arp bolts. My brother in law has an 87 with a twin 16g 1jz doing low 10's. And there are half a dozen more around. Here are videos of the Corolla. Tried to download some Supra videos but couldn't. Can e-mail them though.
http://68.178.140.70/videos/07-01-10-019.wmv
http://www.youtube.com/watch?v=WTP1nzMjDnk
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Are you the guy who's friends with Maeso?
You guys got some quick cars there! I'll add your 86 1j to the list...
