Slow Spool & Chugging
ericshere03
27
Phoenix, AZ
MDCmotorsports said:
Any update on this?
Yea turned out to be the TPS, i got a bran-spanking-new one and all is good, well drives much better...Well for about 5 min till i blew off the IC hose...lol...supposedly the TPS caused the ECU to do funny things with the fuel and timing...i dont know the details, but i did notice the turbo a bit red still, not nearly as bad, maybe the huge boost leak, i could hear the air rushing out of the hoses and would get about 0 PSI, i drove nice after it popped, just to get me home from the dealer...Ill keep this updated as i find out more. ill get the hoses dun good, and post the reasults. Does anybody think stock cat back is too restrictive for a 60-1 CT26? i have a cooleeze megamouth DP and stock cat back.
Eric Wolf
N
NDBoost
Guest
AND BOOST LEAK THXVRYMUUCHH MMKKAYBYE
one other thing, check the Wastegate actuator arm. Mine used to pop off all the time i wonder if that broke on it for some reason.
ericshere03
27
Phoenix, AZ
i got the boost leak after i got the car back from toyota, i need stronger hose clamps, prolly hit up napa for some t bolt clamps... or ill order the cooleeze IC pipe kit since the supra is gonna sit for a while untill i get the DP back.
Intresting point about the WG...ill check it out
