With the timing cover off and the crank set to 0 degrees BOTH cam gears are at the proper top positioning mark. So unless the pins arent in the right position i doubt the cam timing could be an issue. The IC could have a leak, but TBH he would probably end up buying a new IC from ebay that mounts up like stock rather then getting the stock one pressure tested etc. The only TRUE Boost leak i can think of would be the inner fender hose thats plastic, we cant see it easily and havent really looked at it. However the lower IC pipes do appear to be in good shape, but no physical pressure test has been performed on them.
How do you go about making a pressure test tool for our IC pipes?
